Zum Hauptinhalt wechseln
Billy Goat Brush Cutter BC2600HHF 2015 Throttle Control Replacement
Was du brauchst
  1. Billy Goat Brush Cutter BC2600HHF 2015 Throttle Control Replacement, Throttle Cable: Schritt 1, Bild 1 von 3 Billy Goat Brush Cutter BC2600HHF 2015 Throttle Control Replacement, Throttle Cable: Schritt 1, Bild 2 von 3 Billy Goat Brush Cutter BC2600HHF 2015 Throttle Control Replacement, Throttle Cable: Schritt 1, Bild 3 von 3
    • Cut and remove any zip ties securing the throttle cable.
  2. Billy Goat Brush Cutter BC2600HHF 2015 Throttle Control Replacement: Schritt 2, Bild 1 von 2 Billy Goat Brush Cutter BC2600HHF 2015 Throttle Control Replacement: Schritt 2, Bild 2 von 2
    • Use a Phillips #2 driver to remove the screw securing the lower end of the throttle cable.
  3. Billy Goat Brush Cutter BC2600HHF 2015 Throttle Control Replacement: Schritt 3, Bild 1 von 2 Billy Goat Brush Cutter BC2600HHF 2015 Throttle Control Replacement: Schritt 3, Bild 2 von 2
    • Remove the bracket securing the lower end of the throttle cable.
  4. Billy Goat Brush Cutter BC2600HHF 2015 Throttle Control Replacement: Schritt 4, Bild 1 von 3 Billy Goat Brush Cutter BC2600HHF 2015 Throttle Control Replacement: Schritt 4, Bild 2 von 3 Billy Goat Brush Cutter BC2600HHF 2015 Throttle Control Replacement: Schritt 4, Bild 3 von 3
    • Rotate the lower end of the throttle cable to detach it from the throttle.
  5. Billy Goat Brush Cutter BC2600HHF 2015 Throttle Control Replacement: Schritt 5, Bild 1 von 3 Billy Goat Brush Cutter BC2600HHF 2015 Throttle Control Replacement: Schritt 5, Bild 2 von 3 Billy Goat Brush Cutter BC2600HHF 2015 Throttle Control Replacement: Schritt 5, Bild 3 von 3
    • When reinstalling the throttle control cable, check to make sure that the throttle control moves the throttle through its full range of motion.
    • If necessary, loosen the screw securing the lower end of the throttle cable and adjust the position of the cable. Re-tighten the screw and check to make sure that the throttle moves through its full range of motion.
  6. Billy Goat Brush Cutter BC2600HHF 2015 Throttle Control Replacement: Schritt 6, Bild 1 von 2 Billy Goat Brush Cutter BC2600HHF 2015 Throttle Control Replacement: Schritt 6, Bild 2 von 2
    • Use a 7/16" wrench or deep socket to remove the cap from the throttle control.
  7. Billy Goat Brush Cutter BC2600HHF 2015 Throttle Control Replacement: Schritt 7, Bild 1 von 2 Billy Goat Brush Cutter BC2600HHF 2015 Throttle Control Replacement: Schritt 7, Bild 2 von 2
    • Advance the throttle control to expose the gear rack containing the upper end of the throttle cable.
  8. Billy Goat Brush Cutter BC2600HHF 2015 Throttle Control Replacement: Schritt 8, Bild 1 von 3 Billy Goat Brush Cutter BC2600HHF 2015 Throttle Control Replacement: Schritt 8, Bild 2 von 3 Billy Goat Brush Cutter BC2600HHF 2015 Throttle Control Replacement: Schritt 8, Bild 3 von 3
    • Separate the gear rack from the upper end of the throttle cable.
    • Lift and remove the gear rack from the throttle control.
    • If the gear rack doesn't fully detach, advance the throttle control lever a little farther.
    • Lubricate the gear rack with a bit of lithium grease during reassembly.
  9. Billy Goat Brush Cutter BC2600HHF 2015 Throttle Control Replacement: Schritt 9, Bild 1 von 3 Billy Goat Brush Cutter BC2600HHF 2015 Throttle Control Replacement: Schritt 9, Bild 2 von 3 Billy Goat Brush Cutter BC2600HHF 2015 Throttle Control Replacement: Schritt 9, Bild 3 von 3
    • Use a 1/2" wrench to unscrew the upper end of the throttle cable from the throttle control.
    • Slide the throttle cable down out of the bottom of the throttle control, and remove the cable.
  10. Billy Goat Brush Cutter BC2600HHF 2015 Throttle Control Replacement, Throttle Control: Schritt 10, Bild 1 von 2 Billy Goat Brush Cutter BC2600HHF 2015 Throttle Control Replacement, Throttle Control: Schritt 10, Bild 2 von 2
    • Use a Phillips #2 driver to remove the two screws securing the throttle control.
    • While removing the screws, use a 3/8" wrench to counter-hold the lock nuts and prevent them from rotating.
  11. Billy Goat Brush Cutter BC2600HHF 2015 Throttle Control Replacement: Schritt 11, Bild 1 von 2 Billy Goat Brush Cutter BC2600HHF 2015 Throttle Control Replacement: Schritt 11, Bild 2 von 2
    • Remove the throttle control.
Abschluss
4 weitere Nutzer:innen haben diese Anleitung absolviert.
Jeff Suovanen
428.128 Reputation
259 Anleitungen geschrieben
iFixit Mitglied von iFixit
Staff
135 Mitglieder
16.817 Anleitungen geschrieben
Ein Kommentar
the part # is incorrect, it appears that it is 440014 not 440013
JACOB - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 5
Letzte 30 Tage: 11
Insgesamt: 985
