Einleitung
Audio buttons not working? This guide will help you replace the audio/USB port of the Bose SoundLink Mini II. In order to replace these parts make sure to have the necessary tools that are required and the replacement parts. Use caution when working with a charged battery when removing the circuit boards.
Note: This procedure requires removing and reinstalling the battery, which requires the use of a soldering iron and/or a lot of careful disassembly.
Werkzeuge
Ersatzteile
Keine Ersatzteile angegeben.
Carefully lift the battery from the side nearest the four gold contact pins, but don't try to fully remove it yet.
Carefully desolder the four wires from the power supply board in order to completely detach the battery. There is very little room for the soldering iron without damaging the case or the board; you may want to remove the board first.
For help with soldering, see the soldering guide.
With the battery removed the button board will now be visible.
Remove the eight 9mm T9 Torx screws from the circuit board and back panel.
Use a metal spudger to release the ribbon cable connector and remove cable from the audio/USB board.
13 weitere Nutzer haben diese Anleitung absolviert.
