Zum Hauptinhalt wechseln
Cable set up
  1. Cable set up, Cable set up: Schritt 1, Bild 1 von 1
    • Check that the red RCA plug is connected to the red RCA jack labeled "R" (this indicates the Right speaker).
    • Check that the white RCA plug is connected to the white RCA jack labeled "L" (this indicates the Left speaker).
    • To connect the ground clip, loosen the ground screw and insert the clip. Once clip is secure tighten the screw.
    Frag FixBot
    Kommentar hinzufügen
  2. Cable set up: Schritt 2, Bild 1 von 1
    • Check the voltage selector switch to make sure its set to the proper voltage depending on your geographic location.
    • Voltage selector should be set to 115 V/60 Hz in the U.S., or 230 V/50 Hz in other countries.
    Frag FixBot
  3. Cable set up: Schritt 3, Bild 1 von 1
    • Insert power cable into socket.
    Frag FixBot
Ziellinie
Nikolai
281 Reputation
5 Anleitungen geschrieben
Cal Poly, Team 17-14, Regan Fall 2011 Mitglied von Cal Poly, Team 17-14, Regan Fall 2011
CPSU-REGAN-F11S17G14
4 Mitglieder
11 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 27
Insgesamt: 1,259
