Zum Hauptinhalt wechseln
Capresso Perfectea 260 Control System Replacement
Was du brauchst
    1. Capresso Perfectea 260 Control System Replacement, Motherboard: Schritt 1, Bild 1 von 1
      • First, take the base of the device and flip it over.
      Frag FixBot
      Kommentar hinzufügen
    2. Capresso Perfectea 260 Control System Replacement: Schritt 2, Bild 1 von 2 Capresso Perfectea 260 Control System Replacement: Schritt 2, Bild 2 von 2
      • Remove the four 12 mm Phillips #2 screws surrounding the base then lift the bottom half of the base to expose the circuit boards inside the device.
      Frag FixBot
    3. Capresso Perfectea 260 Control System Replacement: Schritt 3, Bild 1 von 1
      • Remove the two 7.5 mm Phillips #2 screws holding in the motherboard
      Frag FixBot
    4. Capresso Perfectea 260 Control System Replacement: Schritt 4, Bild 1 von 1
      • Unplug the wire going into the side of the motherboard
      Frag FixBot
    5. Capresso Perfectea 260 Control System Replacement: Schritt 5, Bild 1 von 2 Capresso Perfectea 260 Control System Replacement: Schritt 5, Bild 2 von 2
      • Use the metal spudger to cut open the rubber covering the latch where it clamps onto the copper tab.
      • Unplug wire at heating element by first using the metal spudger to push the latch in and then pushing it out.
      • Be careful when unplugging the wire as if it is done too forcefully it can damage the connection and make it difficult to connect a new motherboard
      Frag FixBot
    6. Capresso Perfectea 260 Control System Replacement: Schritt 6, Bild 1 von 1
      • Lift the motherboard out of the device
      Frag FixBot
    1. Capresso Perfectea 260 Control System Replacement, Control System: Schritt 7, Bild 1 von 2 Capresso Perfectea 260 Control System Replacement, Control System: Schritt 7, Bild 2 von 2
      • Remove the two 7.5mm Phillips #2 screws from the metal frame.
      • Remove the frame from the assembly.
      Frag FixBot
    2. Capresso Perfectea 260 Control System Replacement: Schritt 8, Bild 1 von 3 Capresso Perfectea 260 Control System Replacement: Schritt 8, Bild 2 von 3 Capresso Perfectea 260 Control System Replacement: Schritt 8, Bild 3 von 3
      • Remove the two 6mm fine thread Phillips #2 screws attaching the small computer chip to the metal frame.
      • Flip over and remove the 7.5 mm fine thread Phillips #2 screw from the back while holding the 5mm nut on the front securely.
      Frag FixBot
    3. Capresso Perfectea 260 Control System Replacement: Schritt 9, Bild 1 von 3 Capresso Perfectea 260 Control System Replacement: Schritt 9, Bild 2 von 3 Capresso Perfectea 260 Control System Replacement: Schritt 9, Bild 3 von 3
      • Find the cable that attaches the small computer chip to the heating element connections.
      • Use the spudger to cut open the rubber coating on the latch where it clamps onto the copper tab.
      • Insert the metal spudger into the rectangular hole on the latch and push toward the tab (away from the wire) to unbend the tab.
      • Push the latch off the tab with the spudger.
      • The tab will come loose suddenly. Make sure that you apply force in a controlled manner to avoid injuring yourself or damaging the other components.
      Frag FixBot
    4. Capresso Perfectea 260 Control System Replacement: Schritt 10, Bild 1 von 3 Capresso Perfectea 260 Control System Replacement: Schritt 10, Bild 2 von 3 Capresso Perfectea 260 Control System Replacement: Schritt 10, Bild 3 von 3
      • Identify the two computer chips that connect the two yellow wires to the temperature controls.
      • Remove the four 5 mm Phillips #1 screws.
      • Remove the two computer chips from their places.
      • The two computer chips are held in place by plastic interference pins. Wiggle the board free of these pins to remove.
      Frag FixBot
    5. Capresso Perfectea 260 Control System Replacement: Schritt 11, Bild 1 von 3 Capresso Perfectea 260 Control System Replacement: Schritt 11, Bild 2 von 3 Capresso Perfectea 260 Control System Replacement: Schritt 11, Bild 3 von 3
      • Find the computer chip over the dial.
      • Remove the three 6mm Phillips #2 screws.
      • Remove the computer chip.
      • Remember the orientation of the computer chip on the dial and which peg goes into which hole.
      • Keep the plastic frame on the bottom of the chip attached.
      Frag FixBot
    6. Capresso Perfectea 260 Control System Replacement: Schritt 12, Bild 1 von 1
      • Unplug the four cables on the left side of the chip.
      • Remember which cable goes to which plug.
      Frag FixBot
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
Cal Poly, Team 6-17, Maness Spring 2015 Mitglied von Cal Poly, Team 6-17, Maness Spring 2015
CPSU-MANESS-S15S6G17
4 Mitglieder
12 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 11
Letzte 30 Tage: 39
Insgesamt: 2,915
