Zum Hauptinhalt wechseln
Casio Exilim EX Z55 Motherboard Replacement
Was du brauchst
  1. Casio Exilim EX Z55 Motherboard Replacement, Front Case: Schritt 1, Bild 1 von 3 Casio Exilim EX Z55 Motherboard Replacement, Front Case: Schritt 1, Bild 2 von 3 Casio Exilim EX Z55 Motherboard Replacement, Front Case: Schritt 1, Bild 3 von 3
    • Remove eight 1.8 mm screws from the left and right sides of the camera using a Phillips #00 screwdriver
  2. Casio Exilim EX Z55 Motherboard Replacement: Schritt 2, Bild 1 von 1
    • Remove the four 3.7 mm screws from the bottom of the camera using a Phillips #00 screwdriver.
  3. Casio Exilim EX Z55 Motherboard Replacement: Schritt 3, Bild 1 von 1
    • Separate the front case from the body of the camera.
  4. Casio Exilim EX Z55 Motherboard Replacement, Back Case: Schritt 4, Bild 1 von 1
    • Separate the back case from the body of the camera.
  5. Casio Exilim EX Z55 Motherboard Replacement, LCD Screen: Schritt 5, Bild 1 von 3 Casio Exilim EX Z55 Motherboard Replacement, LCD Screen: Schritt 5, Bild 2 von 3 Casio Exilim EX Z55 Motherboard Replacement, LCD Screen: Schritt 5, Bild 3 von 3
    • Remove the metal grating located to the right of the LCD screen by inserting the plastic opening tool under the grating and pulling up.
  6. Casio Exilim EX Z55 Motherboard Replacement: Schritt 6, Bild 1 von 1
    • Before removing the side metal bracket, first remove the attached strap knob by twisting it off.
    • Then, remove the side metal bracket by inserting the plastic opening tool under the bracket and pulling up.
  7. Casio Exilim EX Z55 Motherboard Replacement: Schritt 7, Bild 1 von 1
    • Using the plastic opening tool, pry up the LCD screen starting at one of the corners. Insert the tool under one of the corners and lift up.
  8. Casio Exilim EX Z55 Motherboard Replacement: Schritt 8, Bild 1 von 2 Casio Exilim EX Z55 Motherboard Replacement: Schritt 8, Bild 2 von 2
    • Continue to lift the LCD screen all the way up.
    • Be careful not to rip any wires connecting the LCD screen to the top of the camera.
  9. Casio Exilim EX Z55 Motherboard Replacement, Motherboard: Schritt 9, Bild 1 von 2 Casio Exilim EX Z55 Motherboard Replacement, Motherboard: Schritt 9, Bild 2 von 2
    • Remove the orange ribbon cable by grabbing the white tab with your fingers and pulling gently.
    • Potential for device damage: Be careful when handling the fragile parts of the motherboard; direct contact can damage it.
  10. Casio Exilim EX Z55 Motherboard Replacement: Schritt 10, Bild 1 von 1
    • Remove the two 1.7 mm screws from the motherboard using a Phillips #00 screwdriver.
  11. Casio Exilim EX Z55 Motherboard Replacement: Schritt 11, Bild 1 von 1
    • Using the iFixit plastic opening tool, pry the battery case clamps on the front of the camera so that the bottom will come loose.
  12. Casio Exilim EX Z55 Motherboard Replacement: Schritt 12, Bild 1 von 1
    • Detach the inner orange ribbon cable that connects the motherboard to the lens by inserting the iFixit plastic opening tool under the tab and lifting up.
  13. Casio Exilim EX Z55 Motherboard Replacement: Schritt 13, Bild 1 von 1
    • Separate and remove the motherboard from the lens.
    • It will be still be attached by wires and different orange ribbons.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Taylor
46 Reputation
1 Anleitung geschrieben
Cal Poly, Team 9-45, Regan Spring 2012 Mitglied von Cal Poly, Team 9-45, Regan Spring 2012
CPSU-REGAN-S12S9G45
7 Mitglieder
12 Anleitungen geschrieben
Ein Kommentar
I veganlover loved this guide! Although it wasn’t vegan enough
Alex Goodwin - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 5
Letzte 30 Tage: 22
Insgesamt: 929
