Zum Hauptinhalt wechseln
Cen-Tech Seven Function Digital Multimeter Dial Replacement
Was du brauchst
    1. Cen-Tech Seven Function Digital Multimeter Dial Replacement, Position Device: Schritt 1, Bild 1 von 1
      • Place the meter face down, and the back panel and screws can be seen.
      Frag FixBot
      Kommentar hinzufügen
    2. Cen-Tech Seven Function Digital Multimeter Dial Replacement, Remove Back Panel Screws: Schritt 2, Bild 1 von 2 Cen-Tech Seven Function Digital Multimeter Dial Replacement, Remove Back Panel Screws: Schritt 2, Bild 2 von 2
      • Unscrew the two 9mm screws on the back panel using a #0 Phillips screwdriver.
      Frag FixBot
    3. Cen-Tech Seven Function Digital Multimeter Dial Replacement, Remove Back Panel: Schritt 3, Bild 1 von 1
      • Remove the back panel of the device by lifting upward.
      • Remove the battery from the meter before continuing.
      Frag FixBot
    4. Cen-Tech Seven Function Digital Multimeter Dial Replacement, Unscrew Motherboard: Schritt 4, Bild 1 von 2 Cen-Tech Seven Function Digital Multimeter Dial Replacement, Unscrew Motherboard: Schritt 4, Bild 2 von 2
      • Remove the four 7mm Phillips screws holding the circuit board in place.
      Frag FixBot
    5. Cen-Tech Seven Function Digital Multimeter Dial Replacement, Remove Motherboard: Schritt 5, Bild 1 von 1
      • Gently lift the circuit board away from the device casing.
      • Remove the battery after removing the back cover to reduce the chances of short-circuiting the circuit board.
      Frag FixBot
    1. Cen-Tech Seven Function Digital Multimeter Dial Replacement, Locate Dial: Schritt 6, Bild 1 von 1
      • The dial is located in the central part of the device.
      Frag FixBot
    2. Cen-Tech Seven Function Digital Multimeter Dial Replacement, Remove Dial: Schritt 7, Bild 1 von 1
      • Carefully remove dial from device by lifting upward.
      • Clean existing dial or replace if necessary.
      • Take care not to lose the small ball bearings.
      Frag FixBot
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
Clemson, Team 2-4, Benson Fall 2014 Mitglied von Clemson, Team 2-4, Benson Fall 2014
CLEM-BENSON-F14S2G4
4 Mitglieder
24 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 5
Letzte 30 Tage: 22
Insgesamt: 1,222
