Einleitung
This guide shows how to remove and replace the metal fan cover for a Clarke Floor Sander 07014A.
The blower fan will probably be stuck to the motor axle. In order to pry the fan out, you will need two prying tools—either pry bars or hammers with long claws.
Was du brauchst
Twist and pull the dust bag collar to disconnect it from the elbow pipe.
Remove the dust bag.
Peel the rubber sleeve down from the elbow pipe to reveal the pipe socket.
Grasp the elbow pipe with your hands and pull up while twisting to disconnect it from the blower housing.
Remove the elbow pipe.
Remove the four 22mm long Phillips screws around the side of the blower housing.
Lift the blower housing upwards and slide it off of the blower assembly.
Remove the blower housing.
Use snap ring pliers to remove the retaining ring on the top of the fan axle.
Insert a pry bar or the claw end of a hammer under opposing sides of the fan.
Slowly pry up on both sides until the fan loosens from its axle.
Remove the blower fan.
Use snap ring pliers to pry open and remove the retaining clip at the base of the fan axle.
Use a 3/16" hex key to remove the three 16 mm long bolts along the side of the fan cover.
When you are installing the fan cover, note that the cover is not perfectly round. There is a slightly squared edge, which should sit close to the sander's handle.
Your replacement part will most likely have screw covers on the fan cover bolts. Be sure to remove them before installing the fan cover.
3 weitere Personen haben diese Anleitung absolviert.
