Zum Hauptinhalt wechseln
Cleaning the Controller Buttons
Was du brauchst
  1. Cleaning the Controller Buttons, Cleaning the Controller Buttons: Schritt 1, Bild 1 von 2 Cleaning the Controller Buttons, Cleaning the Controller Buttons: Schritt 1, Bild 2 von 2
    • Remove the 9 external screws (4.8 mm Phillips head) on the back of the controller.
    • Remove the back panel from the controller.
    Frag FixBot
    Kommentar hinzufügen
  2. Cleaning the Controller Buttons: Schritt 2, Bild 1 von 3 Cleaning the Controller Buttons: Schritt 2, Bild 2 von 3 Cleaning the Controller Buttons: Schritt 2, Bild 3 von 3
    • Remove the 3 screws (4.8 mm Phillips head) from the back of the white box.
    • Remove the back panel of the joystick box.
    • There are many small plastic components loose in this box; be careful not to lose these.
    • Separate the rubber pads and plastic buttons from the controller.
    Frag FixBot
  3. Cleaning the Controller Buttons: Schritt 3, Bild 1 von 2 Cleaning the Controller Buttons: Schritt 3, Bild 2 von 2
    • Using a soft cleaning material, clean the plastic buttons.
    • Using a toothpick, clean the pole slot, shown at the right of the Q-Tip.
    Frag FixBot
  4. Cleaning the Controller Buttons: Schritt 4, Bild 1 von 2 Cleaning the Controller Buttons: Schritt 4, Bild 2 von 2
    • Using a damp, soft cleaning material, clean the rubber button pads.
    • To ensure that no electrical damage occurs, ensure that you dry the pieces completely after cleaning them.
    Frag FixBot
  5. Cleaning the Controller Buttons, Put it back together: Schritt 5, Bild 1 von 1
    • Reinsert the buttons, ensuring that the rubber, cylindrical pieces protruding from the buttons are lined up with their corresponding circuits.
    Frag FixBot
Abschluss
Follow these steps in reverse order to reassemble your device.
7 weitere Personen haben diese Anleitung absolviert.
UC Santa Barbara, Team 1-3, Bradley Spring 2013 Mitglied von UC Santa Barbara, Team 1-3, Bradley Spring 2013
UCSB-BRADLEY-S13S1G3
2 Mitglieder
2 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 13
Letzte 30 Tage: 48
Insgesamt: 6,582
