Zum Hauptinhalt wechseln
Connect Four Electronic Handheld Back Casing Replacement
Was du brauchst
  1. Connect Four Electronic Handheld Back Casing Replacement, Ensure the device is off.: Schritt 1, Bild 1 von 1
    • Make sure the Connect Four Electronic Handheld is off by allowing it to shut off automatically.
    Frag FixBot
    Kommentar hinzufügen
  2. Connect Four Electronic Handheld Back Casing Replacement, Removing the battery casing.: Schritt 2, Bild 1 von 2 Connect Four Electronic Handheld Back Casing Replacement, Removing the battery casing.: Schritt 2, Bild 2 von 2
    • Using a Phillips head screwdriver, remove the (9.1mm length) #2 screw in the middle of the battery casing.
    • Slide the cover off and remove the battery.
    Frag FixBot
  3. Connect Four Electronic Handheld Back Casing Replacement, Removing/Replacing the Back Casing: Schritt 3, Bild 1 von 2 Connect Four Electronic Handheld Back Casing Replacement, Removing/Replacing the Back Casing: Schritt 3, Bild 2 von 2
    • Using a Phillips head screwdriver, remove the four (7.1mm- length) #3 screws that hold the back casing in place.
    • Carefully remove the back casing.
    • When removing the back casing, make sure not to rupture the wires that connect the speaker to the circuit board.
    Frag FixBot
Abschluss
Wil
313 Reputation
3 Anleitungen geschrieben
Baylor, Team 8-11, Williams Fall 2014 Mitglied von Baylor, Team 8-11, Williams Fall 2014
BU-WILLIAMS-F14S8G11
3 Mitglieder
12 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 38
Insgesamt: 462
