Zum Hauptinhalt wechseln
Connect Four Electronic Handheld Buttons Replacement
Was du brauchst
    1. Connect Four Electronic Handheld Buttons Replacement, Ensure the device is off.: Schritt 1, Bild 1 von 1
      • Make sure the Connect Four Electronic Handheld is off by allowing it to shut off automatically.
      Frag FixBot
      Kommentar hinzufügen
    2. Connect Four Electronic Handheld Buttons Replacement, Removing the battery casing.: Schritt 2, Bild 1 von 2 Connect Four Electronic Handheld Buttons Replacement, Removing the battery casing.: Schritt 2, Bild 2 von 2
      • Using a Phillips head screwdriver, remove the (9.1mm length) #2 screw in the middle of the battery casing.
      • Slide the cover off and remove the battery.
      Frag FixBot
    1. Connect Four Electronic Handheld Buttons Replacement, Removing/Replacing the Back Casing: Schritt 3, Bild 1 von 2 Connect Four Electronic Handheld Buttons Replacement, Removing/Replacing the Back Casing: Schritt 3, Bild 2 von 2
      • Using a Phillips head screwdriver, remove the four (7.1mm- length) #3 screws that hold the back casing in place.
      • Carefully remove the back casing.
      • When removing the back casing, make sure not to rupture the wires that connect the speaker to the circuit board.
      Frag FixBot
    1. Connect Four Electronic Handheld Buttons Replacement, Detaching the Circuit Board: Schritt 4, Bild 1 von 3 Connect Four Electronic Handheld Buttons Replacement, Detaching the Circuit Board: Schritt 4, Bild 2 von 3 Connect Four Electronic Handheld Buttons Replacement, Detaching the Circuit Board: Schritt 4, Bild 3 von 3
      • Using a Phillips head screwdriver, remove the six (0.25"-length) #3 screws that hold down the cpu board.
      • Using a spudger, lever the circuit board just enough to where you can easily access the button sheet.
      Frag FixBot
    2. Connect Four Electronic Handheld Buttons Replacement, Removing/ Replacing the Button Sheet: Schritt 5, Bild 1 von 1
      • Take out the button sheet, and replace it with a new one.
      Frag FixBot
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
Baylor, Team 8-11, Williams Fall 2014 Mitglied von Baylor, Team 8-11, Williams Fall 2014
BU-WILLIAMS-F14S8G11
3 Mitglieder
12 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 29
Insgesamt: 711
