Einleitung
Use this guide to remove the core assembly in your TicWatch Pro.
Was du brauchst
Before starting repairs, take your watch off the charger and power it down.
Remove the four 3.9 mm-long Torx T3 screws.
Carefully lift the back cover by the watch crown edge and swing it open to an upward position.
Use the flat end of a spudger to pry up and disconnect the sensor flex cable.
Insert the flat end of a spudger into the notch at the upper end of the white plastic frame.
Use your spudger as a lever and pry up the core assembly.
Carefully lift the loose edge of the core assembly up and swing it to a 100-degree angle.
Use the flat end of a spudger to pry up and disconnect the sensor flex cable from the core assembly.
Use the flat end of a spudger to pry up and disconnect the display flex cable from the core assembly.
Repair didn’t go as planned? Check out our Answers community for help.
4 weitere Nutzer:innen haben diese Anleitung absolviert.
Ein Kommentar
Hello... in the event that you have submerged the smartwatch in salt water and it does not work, is there a solution?
