Zum Hauptinhalt wechseln
Cricut Maker 3 Blade Housing Replacement
  1. Cricut Maker 3 Blade Housing Replacement, Prepare your Cricut for disassembly: Schritt 1, Bild 1 von 3 Cricut Maker 3 Blade Housing Replacement, Prepare your Cricut for disassembly: Schritt 1, Bild 2 von 3 Cricut Maker 3 Blade Housing Replacement, Prepare your Cricut for disassembly: Schritt 1, Bild 3 von 3
    • Be very careful not to cut yourself when working near the Cricut's small, sharp blade, located in the tool holder within the Cricut.
    • Power off the Cricut and unplug all cables.
  2. Cricut Maker 3 Blade Housing Replacement, Open the Cricut: Schritt 2, Bild 1 von 2 Cricut Maker 3 Blade Housing Replacement, Open the Cricut: Schritt 2, Bild 2 von 2
    • Open the Cricut by lifting the top silver lid. The front tray will also open.
  3. Cricut Maker 3 Blade Housing Replacement, Open the clamp: Schritt 3, Bild 1 von 2 Cricut Maker 3 Blade Housing Replacement, Open the clamp: Schritt 3, Bild 2 von 2
    • Partially open clamp B on the tool holder by pulling the plastic latch away from the tool holder.
  4. Cricut Maker 3 Blade Housing Replacement: Schritt 4, Bild 1 von 2 Cricut Maker 3 Blade Housing Replacement: Schritt 4, Bild 2 von 2
    • While holding the blade housing in the tool holder, fully open clamp B by pulling the plastic latch to the right.
  5. Cricut Maker 3 Blade Housing Replacement, Remove the blade housing: Schritt 5, Bild 1 von 2 Cricut Maker 3 Blade Housing Replacement, Remove the blade housing: Schritt 5, Bild 2 von 2
    • Grab the blade housing by the top and remove it from the tool holder.
Abschluss
Spencer Pennington
17.094 Reputation
113 Anleitungen geschrieben
iFixit Mitglied von iFixit
Staff
119 Mitglieder
19.523 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 11
Insgesamt: 102
