Zum Hauptinhalt wechseln
Cricut Maker 3 Blade Replacement
  1. Cricut Maker 3 Blade Replacement, Prepare your Cricut for disassembly: Schritt 1, Bild 1 von 3 Cricut Maker 3 Blade Replacement, Prepare your Cricut for disassembly: Schritt 1, Bild 2 von 3 Cricut Maker 3 Blade Replacement, Prepare your Cricut for disassembly: Schritt 1, Bild 3 von 3
    • Be very careful not to cut yourself when working near the Cricut's small, sharp blade, located in the tool holder within the Cricut.
    • Power off the Cricut and unplug all cables.
  2. Cricut Maker 3 Blade Replacement, Open the Cricut: Schritt 2, Bild 1 von 2 Cricut Maker 3 Blade Replacement, Open the Cricut: Schritt 2, Bild 2 von 2
    • Open the Cricut by lifting the top silver lid. The front tray will also open.
  3. Cricut Maker 3 Blade Replacement, Open the clamp: Schritt 3, Bild 1 von 2 Cricut Maker 3 Blade Replacement, Open the clamp: Schritt 3, Bild 2 von 2
    • Partially open clamp B on the tool holder by pulling the plastic latch away from the tool holder.
  4. Cricut Maker 3 Blade Replacement: Schritt 4, Bild 1 von 2 Cricut Maker 3 Blade Replacement: Schritt 4, Bild 2 von 2
    • While holding the blade housing in the tool holder, fully open clamp B by pulling the plastic latch to the right.
  5. Cricut Maker 3 Blade Replacement, Remove the blade housing: Schritt 5, Bild 1 von 2 Cricut Maker 3 Blade Replacement, Remove the blade housing: Schritt 5, Bild 2 von 2
    • Grab the blade housing by the top and remove it from the tool holder.
  6. Cricut Maker 3 Blade Replacement, Remove the blade: Schritt 6, Bild 1 von 2 Cricut Maker 3 Blade Replacement, Remove the blade: Schritt 6, Bild 2 von 2
    • Be careful not to cut yourself while working near the small, sharp blade.
    • Hold the blade housing between your index finger and middle finger with the blade pointed away from your palm.
    • Use your thumb to press the plunger to push the blade out of the housing.
  7. Cricut Maker 3 Blade Replacement: Schritt 7, Bild 1 von 2 Cricut Maker 3 Blade Replacement: Schritt 7, Bild 2 von 2
    • Firmly grip the flat sides of the blade to avoid cutting yourself.
    • With the plunger still pressed, use your free hand to carefully grip the blade and pull it out of the housing to remove it.
    • The blade is held in with a magnet and should come out of the housing easily.
Abschluss
Spencer Pennington
17.094 Reputation
113 Anleitungen geschrieben
iFixit Mitglied von iFixit
Staff
119 Mitglieder
19.523 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 7
Letzte 30 Tage: 15
Insgesamt: 75
