Was du brauchst
Use Phillips #00 Screwdriver to remove the three screws that hold the upper portion of the access panel.
Remove the blade cutter assembly.
Use Phillips #00 Screwdriver to remove the last two screws located in the battery panel that holds the bottom portion of the access panel.
Gently remove the access panel from the right side of the device.
Use Phillips #00 Screwdriver to remove three screws that hold down the circuit board.
Gently lift the bottom of the circuit board, revealing the keypad.
