Einleitung
This guide will teach you how to properly replace your forward/reverse switch for this device.
Was du brauchst
Compress the buttons on either side of the battery and lift the drill away from battery.
Disconnect the forward/reverse switch from the trigger by pulling the mechanism out and leaving the switch in the frame.
To replace just pull the switch out and put the new one in the opening.
