Zum Hauptinhalt wechseln
Dell Adamo 13 Battery Replacement
  1. Dell Adamo 13 Battery Replacement, Battery: Schritt 1, Bild 1 von 1
    • There is no external access to the battery. Please make sure the at the battery has been drained or disabled through BIOS before beginning.
    • Flip the device over.
  2. Dell Adamo 13 Battery Replacement: Schritt 2, Bild 1 von 1
    • Remove the bottom cover by unsnapping the clips around the edge of the computer.
    • You may hear a slight pop when you pull the cover off.
  3. Dell Adamo 13 Battery Replacement: Schritt 3, Bild 1 von 1
    • Disconnect orange film wire harness from the slot it is connected to.
    • The bottom cover and battery are one piece and will be replaced as a unit.
    • Remove the battery from the device.
Abschluss
For optimal performance, after completing this guide, calibrate your newly installed battery.
UMass Dartmouth, Team 3-7, Sinclaire Fall 2021 Mitglied von UMass Dartmouth, Team 3-7, Sinclaire Fall 2021
UMASSD-SINCLAIRE-F21S3G7
3 Mitglieder
7 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 2
Letzte 30 Tage: 15
Insgesamt: 486
