Einleitung
Use this guide to replace the battery in a Dell Adamo 13 laptop computer. Though the battery is rechargeable, it may need to be be replaced after repeated use.
Some signs that you may need to replace your battery are it having very little overall use time, the laptop overheating often or the battery itself taking an extensive amount of time to charge.
There are no special skills or tools needed to complete this guide.
Before beginning, be sure to completely power off your device.
Remove the bottom cover by unsnapping the clips around the edge of the computer.
Disconnect orange film wire harness from the slot it is connected to.
Remove the battery from the device.
For optimal performance, after completing this guide, calibrate your newly installed battery.
