Zum Hauptinhalt wechseln
Dell Latitude 3189 Battery Replacement
Was du brauchst
  1. Dell Latitude 3189 Battery Replacement, Lower Case: Schritt 1, Bild 1 von 2 Dell Latitude 3189 Battery Replacement, Lower Case: Schritt 1, Bild 2 von 2
    • Before beginning, power off and unplug the device.
    • Use a Phillips screwdriver to loosen the seven captive screws that secure the lower case.
  2. Dell Latitude 3189 Battery Replacement: Schritt 2, Bild 1 von 3 Dell Latitude 3189 Battery Replacement: Schritt 2, Bild 2 von 3 Dell Latitude 3189 Battery Replacement: Schritt 2, Bild 3 von 3
    • Insert a nylon spudger between the lower case and chassis at the two hinge spaces on the back side of the laptop and pry up the lower case.
    • Do not use metal items to pry the base cover off, like a screwdriver, as it could slip and damage internal components.
    • Avoid prying at the ports.
  3. Dell Latitude 3189 Battery Replacement: Schritt 3, Bild 1 von 2 Dell Latitude 3189 Battery Replacement: Schritt 3, Bild 2 von 2
    • Grip and lift the lower case up and away.
    • If you feel any significant resistance, double check that all of the screws are loosened.
  4. Dell Latitude 3189 Battery Replacement: Schritt 4, Bild 1 von 3 Dell Latitude 3189 Battery Replacement: Schritt 4, Bild 2 von 3 Dell Latitude 3189 Battery Replacement: Schritt 4, Bild 3 von 3
    • Before performing any operations within the laptop, unplug the battery.
    • Pull the white battery connector directly out of its motherboard port.
    • Do not pull on the wires.
  5. Dell Latitude 3189 Battery Replacement, Battery: Schritt 5, Bild 1 von 2 Dell Latitude 3189 Battery Replacement, Battery: Schritt 5, Bild 2 von 2
    • Use a Phillips #0 screwdriver to remove the three 3.2 mm screws that secure the battery.
  6. Dell Latitude 3189 Battery Replacement: Schritt 6, Bild 1 von 2 Dell Latitude 3189 Battery Replacement: Schritt 6, Bild 2 von 2
    • Grip the battery and lift it up and out of the chassis.
Abschluss
For optimal performance, calibrate your newly installed battery after completing this guide.
Eine weitere Person hat diese Anleitung absolviert.
Bryan Pratt
601 Reputation
6 Anleitungen geschrieben
University of Memphis, Team 2-3, Sneed Spring 2024 Mitglied von University of Memphis, Team 2-3, Sneed Spring 2024
UM-SNEED-S24S2G3
4 Mitglieder
7 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 14
Insgesamt: 62
