Zum Hauptinhalt wechseln
Dell Precision M3800 RAM (Memory) Replacement
Was du brauchst
    1. Dell Precision M3800 RAM (Memory) Replacement, Back Cover: Schritt 1, Bild 1 von 2 Dell Precision M3800 RAM (Memory) Replacement, Back Cover: Schritt 1, Bild 2 von 2
      • Be sure to power off and unplug your device before you begin your repair.
      • Use a T5 Torx screwdriver to unscrew the ten 3mm screws on the laptop back cover.
      • iFixit’s magnetic project mat is great for keeping the screws in one place.
      • Lift up the silver cover from the back panel to reveal two screws.
      • Use a Phillips screwdriver to remove the two screws underneath the silver cover.
      Frag FixBot
      Kommentar hinzufügen
    2. Dell Precision M3800 RAM (Memory) Replacement: Schritt 2, Bild 1 von 1
      • Use an opening tool to pry around the edges of the back panel to loosen the panel.
      • Remove the back panel.
      Frag FixBot
    1. Dell Precision M3800 RAM (Memory) Replacement, Battery: Schritt 3, Bild 1 von 1
      • Disconnect the battery cable from the system board [1].
      • Use a Phillips screwdriver to remove the four screws securing the battery to the laptop.
      • Lift the battery off the computer [2].
      Frag FixBot
    1. Dell Precision M3800 RAM (Memory) Replacement, RAM (Memory): Schritt 4, Bild 1 von 3 Dell Precision M3800 RAM (Memory) Replacement, RAM (Memory): Schritt 4, Bild 2 von 3 Dell Precision M3800 RAM (Memory) Replacement, RAM (Memory): Schritt 4, Bild 3 von 3
      • Pull the small silver RAM tabs outwards to pop it out of its place in the laptop body.
      • Remove the RAM from the laptop body (it should easily come out after pulling the silver tabs).
      Frag FixBot
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 15
Insgesamt: 724
