Zum Hauptinhalt wechseln
Dell Precision M4700 CPU Replacement
Was du brauchst
  1. Dell Precision M4700 CPU Replacement, Optical Drive: Schritt 1, Bild 1 von 1
    • Slide the release latch to unlock the battery.
    • Flip and remove the battery from the computer.
  2. Dell Precision M4700 CPU Replacement: Schritt 2, Bild 1 von 2 Dell Precision M4700 CPU Replacement: Schritt 2, Bild 2 von 2
    • Remove the two 3mm screws that secure the base cover to the computer with a Phillips #00 screwdriver.
    • Press the rubber tabs towards the rear of the computer to disengage the base cover.
    • Flip and remove the base cover from the computer.
  3. Dell Precision M4700 CPU Replacement: Schritt 3, Bild 1 von 2 Dell Precision M4700 CPU Replacement: Schritt 3, Bild 2 von 2
    • Remove the 3mm screw that secures the optical drive to the computer with a Phillips #00 screwdriver.
    • Slide the optical drive out.
  4. Dell Precision M4700 CPU Replacement, CPU: Schritt 4, Bild 1 von 2 Dell Precision M4700 CPU Replacement, CPU: Schritt 4, Bild 2 von 2
    • Pry up the keyboard trim starting from the top-inner edge with a plastic opening tool or spudger.
    • Pry up the bottom edge of the keyboard trim from the top-inner edge with a plastic opening tool or spudger.
  5. Dell Precision M4700 CPU Replacement: Schritt 5, Bild 1 von 3 Dell Precision M4700 CPU Replacement: Schritt 5, Bild 2 von 3 Dell Precision M4700 CPU Replacement: Schritt 5, Bild 3 von 3
    • Remove the four 3mm screws that secure the keyboard to the computer with a Phillips #00 screwdriver.
    • Starting from the bottom of the keyboard, separate the keyboard from the computer and flip the keyboard over.
    • Disconnect the keyboard-data cable from the system board by flipping up the locking tab of the ZIF connector and gently pulling out the cable.
    • Remove the keyboard.
  6. Dell Precision M4700 CPU Replacement: Schritt 6, Bild 1 von 2 Dell Precision M4700 CPU Replacement: Schritt 6, Bild 2 von 2
    • Remove four 5mm screws that secure the hard drive to the computer with a Phillips #00 screwdriver.
    • Unscrew the 3mm Phillips #00 locking screw. Slide the release latch to unlock the hard drive.
    • Slide the hard drive out from the computer.
  7. Dell Precision M4700 CPU Replacement: Schritt 7, Bild 1 von 3 Dell Precision M4700 CPU Replacement: Schritt 7, Bild 2 von 3 Dell Precision M4700 CPU Replacement: Schritt 7, Bild 3 von 3
    • Remove the five 3mm Phillips #00 screws that secure the lower palm rest to the bottom of the laptop.
    • Remove the twelve 5mm Phillips #00 screws that secure the upper palm rest to the keyboard side of the laptop.
  8. Dell Precision M4700 CPU Replacement: Schritt 8, Bild 1 von 3 Dell Precision M4700 CPU Replacement: Schritt 8, Bild 2 von 3 Dell Precision M4700 CPU Replacement: Schritt 8, Bild 3 von 3
    • Disconnect the ribbon cables that connect the palmrest to the bottom of the device.
    • Pull on the tabs to disconnect the two wider connections.
  9. Dell Precision M4700 CPU Replacement: Schritt 9, Bild 1 von 2 Dell Precision M4700 CPU Replacement: Schritt 9, Bild 2 von 2
    • Pry up between the palmrest and case with a plastic opening tool, starting on the left side.
    • Work around the side farthest from the screen prying the palmrest up.
  10. Dell Precision M4700 CPU Replacement: Schritt 10, Bild 1 von 2 Dell Precision M4700 CPU Replacement: Schritt 10, Bild 2 von 2
    • Remove the two 5mm screws connecting the fan to the device with a Phillips #00 screwdriver.
    • Disconnect the wires connecting the fan to the motherboard.
  11. Dell Precision M4700 CPU Replacement: Schritt 11, Bild 1 von 2 Dell Precision M4700 CPU Replacement: Schritt 11, Bild 2 von 2
    • Unscrew the four captive screws with a Phillips #00 screwdriver.
    • Pull the CPU heatsink out. To remove it, grab the heatsink and pull it out and upward.
    • Captive screws should not be able to be removed. They only screw, they do not come out.
    • Be sure to clean both contact points on the CPU and heatsink with isopropyl alcohol and reapply fresh thermal paste before reinstalling the heatsink.
  12. Dell Precision M4700 CPU Replacement: Schritt 12, Bild 1 von 2 Dell Precision M4700 CPU Replacement: Schritt 12, Bild 2 von 2
    • Unlock the CPU by using flathead screwdriver on the circular lock and turning.
    • Using two fingers, grab the CPU and lift it directly upwards from the motherboard gently.
    • Once it is unlocked, it will come out very easily so do not use excessive force and be sure to avoid bending any of the pins located on the underside.
Abschluss
2 weitere Personen haben diese Anleitung absolviert.
Dylan
361 Reputation
2 Anleitungen geschrieben
University of Memphis, Team S4-G5, Kim Fall 2019 Mitglied von University of Memphis, Team S4-G5, Kim Fall 2019
UM-KIM-F19S4G5
4 Mitglieder
3 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 6
Letzte 30 Tage: 39
Insgesamt: 1,879
