Zum Hauptinhalt wechseln
Dell VRC100-R Battery Replacement
  1. Dell VRC100-R Battery Replacement, Battery: Schritt 1, Bild 1 von 3 Dell VRC100-R Battery Replacement, Battery: Schritt 1, Bild 2 von 3 Dell VRC100-R Battery Replacement, Battery: Schritt 1, Bild 3 von 3
    • Orient your controller so that the black ring is on the bottom and the buttons are facing away from yourself.
    • Place your thumb on the small arrow that is on the controller's battery cover and firmly push upwards.
    • Slide the cover off and separate it from the controller.
    Frag FixBot
    Kommentar hinzufügen
  2. Dell VRC100-R Battery Replacement: Schritt 2, Bild 1 von 2 Dell VRC100-R Battery Replacement: Schritt 2, Bild 2 von 2
    • Remove the right battery by pushing the positive end down and pulling the battery out toward yourself.
    • Repeat the procedure for the left battery.
    Frag FixBot
Abschluss
Kenneth Liu
169 Reputation
2 Anleitungen geschrieben
Cal Poly, Team S18-G3, Livingston Spring 2018 Mitglied von Cal Poly, Team S18-G3, Livingston Spring 2018
CPSU-LIVINGSTON-S18S18G3
4 Mitglieder
5 Anleitungen geschrieben
1 Kommentar zur Anleitung
Hi,
I will like to know if using 1.2V ni-mh rechargeable batteries will affect the performance of the device, as it’s been a debate for long and will appreciate your technical point of view.
Many thanks.
Baba Nam Kevalam - Antwort Teilen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 5
Letzte 30 Tage: 52
Insgesamt: 1,182
