Zum Hauptinhalt wechseln
Dell XPS 12 9250 Battery Replacement
Was du brauchst
  1. Dell XPS 12 9250 Battery Replacement, Removing the Back Cover: Schritt 1, Bild 1 von 2 Dell XPS 12 9250 Battery Replacement, Removing the Back Cover: Schritt 1, Bild 2 von 2
    • Turn the tablet over.
    • Remove the screws that secure the back-cover assembly to the display assembly.
    • Using a plastic scribe, pry up along the edges of the back-cover assembly.
    • Carefully, lift the back-cover assembly and turn it over.
  2. Dell XPS 12 9250 Battery Replacement, Removing the Battery: Schritt 2, Bild 1 von 1
    • Remove the screws that secure the battery to the back-cover assembly.
    • Disconnect the battery cable from the system board.
    • Lift the battery, along with its cable, off the back-cover assembly.
Abschluss
4 weitere Nutzer:innen haben diese Anleitung absolviert.
Johnathan Hammond
44.953 Reputation
408 Anleitungen geschrieben
RampUP America, Inc. Mitglied von RampUP America, Inc.
Community
42 Mitglieder
1.985 Anleitungen geschrieben
Ein Kommentar
The 4 screws on the edge are NOT phillips head screws. They appear to be Tork.
ponchojack - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 6
Letzte 30 Tage: 15
Insgesamt: 2,393
