Einleitung
In this guide, we will be showing you how to remove and replace the Battery.
Was du brauchst
Schritt 1 Back Cover
Achtung: Die Schritte 1-3 stammen von einer Anleitung, die derzeit bearbeitet wird.
Use your fingers or a spudger to pry up the system badge from the bottom of the laptop.
Use a Phillips screwdriver to remove the eleven screws securing the base cover.
Beginning with the side opposite the power switch, use your fingers to pry up the base cover from the laptop.
Carefully lift the base cover around the power switch and remove the cover.
Slide the battery cable connector out of its system board socket.
Remove the screws that secure the battery to the palm-rest assembly.
Lift and remove the battery along with its cable.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
