Zum Hauptinhalt wechseln
Digital2 Platinum Pad 9 Battery Replacement
Was du brauchst
  1. Digital2 Platinum Pad 9 Battery Replacement, External Cover: Schritt 1, Bild 1 von 1
    • Take the plastic opening tool and insert it into the crease between the screen and the plastic casing and press down.
  2. Digital2 Platinum Pad 9 Battery Replacement: Schritt 2, Bild 1 von 2 Digital2 Platinum Pad 9 Battery Replacement: Schritt 2, Bild 2 von 2
    • After inserting the plastic opening tool, run it around the device a few times to loosen the external cover.
  3. Digital2 Platinum Pad 9 Battery Replacement: Schritt 3, Bild 1 von 2 Digital2 Platinum Pad 9 Battery Replacement: Schritt 3, Bild 2 von 2
    • Once you've gone around a few times a corner will pop up, insert the opening tool there and repeat step 2 with slightly more pressure. Do this until every section of the backing has popped up.
    • Then just remove the backing.
  4. Digital2 Platinum Pad 9 Battery Replacement, Battery: Schritt 4, Bild 1 von 1
    • The battery is the bigger square object in the center of the device held down by 3 pieces of yellow tape.
  5. Digital2 Platinum Pad 9 Battery Replacement: Schritt 5, Bild 1 von 1
    • Carefully remove the tape that is holding down the battery.
  6. Digital2 Platinum Pad 9 Battery Replacement: Schritt 6, Bild 1 von 2 Digital2 Platinum Pad 9 Battery Replacement: Schritt 6, Bild 2 von 2
    • Lift up the battery it will be glued to the device.
    • Be sure to gently work it to loosen and remove so that you do not damage your device.
  7. Digital2 Platinum Pad 9 Battery Replacement: Schritt 7, Bild 1 von 1
Abschluss
UMass Dartmouth, Team 5-6, Landers Spring 2016 Mitglied von UMass Dartmouth, Team 5-6, Landers Spring 2016
UMASSD-LANDERS-S16S5G6
3 Mitglieder
6 Anleitungen geschrieben
Ein Kommentar
Where can one buy the battery?
BedfordGlen Board - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 2
Letzte 30 Tage: 8
Insgesamt: 301
