Einleitung
If your screen has become damaged--cracked, scratched, or more--then it is in need of replacement. This guide will show you how to remove the battery and motherboard in order to access your broken screen.
Was du brauchst
To begin, locate the two 4.9mm Phillips #00 screws at the top corners of the case and remove them.
Squeeze the plastic opening tool in between the seam where the screen joins the plastic case.
Begin separating the bottom of the case from the screen by carefully going around the whole edge of the case and slowly prying it apart.
In diesem Schritt verwendetes Werkzeug:Tweezers$4.99
Carefully place the bottom lid next to the screen case. The power/speaker buttons should be visible at the corner of the lid. Remove the buttons with the tweezers.
Begin removing the black tape covering the motherboard inside the tablet.
You will need to desolder the two contact points that connect the battery to the mother board.
Touch the hot iron to the contact points and gently pull on the wires to loosen them from the solder. They should release easily.
Using the black nylon spudger, get underneath the battery and begin prying it loose from the rest of the tablet.
The motherboard will need to be removed in order to access the screen.
To remove the motherboard you must first unscrew four 4.9mm Phillips #00 screws.
To finish removing the motherboard you must release the two data cables holding the screen to it.
Use the black nylon spudger to lift the gray clips up 90° on the white connectors.
You can now remove the data cables from the slots and lift the motherboard out from the device.
After removing the motherboard, use the black nylon spudger to pop the screen out of the housing holding it to the front of the screen case.
Pull the thin plastic screen casing apart and you can remove the damaged screen.
Eine weitere Person hat diese Anleitung absolviert.
