Zum Hauptinhalt wechseln
Disassembling Compaq Mini 110 Wireless Module
Was du brauchst
  1. Disassembling Compaq Mini 110 Wireless Module, Battery: Schritt 1, Bild 1 von 2 Disassembling Compaq Mini 110 Wireless Module, Battery: Schritt 1, Bild 2 von 2
    • Locate the battery and the battery tabs on the bottom of the Compaq Mini.
    Frag FixBot
    Kommentar hinzufügen
  2. Disassembling Compaq Mini 110 Wireless Module: Schritt 2, Bild 1 von 3 Disassembling Compaq Mini 110 Wireless Module: Schritt 2, Bild 2 von 3 Disassembling Compaq Mini 110 Wireless Module: Schritt 2, Bild 3 von 3
    • Push both tabs inward simultaneously and slide the battery out.
    Frag FixBot
  3. Disassembling Compaq Mini 110 Wireless Module, RAM: Schritt 3, Bild 1 von 2 Disassembling Compaq Mini 110 Wireless Module, RAM: Schritt 3, Bild 2 von 2
    • Use a Philips #0 screwdriver to unscrew the two screws covering the memory compartment on the bottom of the laptop and remove the cover.
    Frag FixBot
  4. Disassembling Compaq Mini 110 Wireless Module: Schritt 4, Bild 1 von 1
    • Push out the side tabs simultaneously and pull out the old RAM module.
    • When inserting a new RAM stick, be sure to evenly insert the gold pins in the same orientation that the old module was removed. While sliding the module in, press the side tabs in place.
    Frag FixBot
  5. Disassembling Compaq Mini 110 Wireless Module, Keyboard: Schritt 5, Bild 1 von 2 Disassembling Compaq Mini 110 Wireless Module, Keyboard: Schritt 5, Bild 2 von 2
    • Remove the rubber pads located on the corners of your Compaq Mini.
    • There may be junk underneath it. This is residue left from the glue that held on the rubber pad. Just scrape it away to find the screw.
    Frag FixBot
  6. Disassembling Compaq Mini 110 Wireless Module: Schritt 6, Bild 1 von 2 Disassembling Compaq Mini 110 Wireless Module: Schritt 6, Bild 2 von 2
    • Unscrew all the corner screws. There are four total, one under each rubber pad.
    Frag FixBot
  7. Disassembling Compaq Mini 110 Wireless Module: Schritt 7, Bild 1 von 2 Disassembling Compaq Mini 110 Wireless Module: Schritt 7, Bild 2 von 2
    • Unscrew the screw for the bottom case located in the RAM compartment.
    Frag FixBot
  8. Disassembling Compaq Mini 110 Wireless Module: Schritt 8, Bild 1 von 2 Disassembling Compaq Mini 110 Wireless Module: Schritt 8, Bild 2 von 2
    • Remove the three screws in the silver tabs at the back of the keyboard.
    • These are located at the back of the base under the screen.
    • Lift the keyboard away from the laptop.
    Frag FixBot
  9. Disassembling Compaq Mini 110 Wireless Module, Hard Drive: Schritt 9, Bild 1 von 1
    • Remove the three screws holding the panel in place.
    Frag FixBot
  10. Disassembling Compaq Mini 110 Wireless Module: Schritt 10, Bild 1 von 2 Disassembling Compaq Mini 110 Wireless Module: Schritt 10, Bild 2 von 2
    • Pull up on the tab to remove the hard drive.
    Frag FixBot
  11. Disassembling Compaq Mini 110 Wireless Module, Top Cover: Schritt 11, Bild 1 von 1
    • Remove the eight screws that are from the plastic top cover.
    Frag FixBot
  12. Disassembling Compaq Mini 110 Wireless Module: Schritt 12, Bild 1 von 3 Disassembling Compaq Mini 110 Wireless Module: Schritt 12, Bild 2 von 3 Disassembling Compaq Mini 110 Wireless Module: Schritt 12, Bild 3 von 3
    • Pry up the top plastic cover using a spudger.
    • These two tabs under the screen need to be pushed in with a spudger.
    Frag FixBot
  13. Disassembling Compaq Mini 110 Wireless Module: Schritt 13, Bild 1 von 2 Disassembling Compaq Mini 110 Wireless Module: Schritt 13, Bild 2 von 2
    • Remove the cable by carefully pulling it up.
    • Be careful when lifting up the cover because the track pad is still attached.
    Frag FixBot
  14. Disassembling Compaq Mini 110 Wireless Module, Wireless Module: Schritt 14, Bild 1 von 1
    • Remove the two screws holding the module in place.
    Frag FixBot
  15. Disassembling Compaq Mini 110 Wireless Module: Schritt 15, Bild 1 von 1
    • Detach the two wires.
    Frag FixBot
  16. Disassembling Compaq Mini 110 Wireless Module: Schritt 16, Bild 1 von 1
    • Just pull it out.
    Frag FixBot
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
alea
1.429 Reputation
14 Anleitungen geschrieben
Cal Poly, Team 22-2, Maness Fall 2010 Mitglied von Cal Poly, Team 22-2, Maness Fall 2010
CPSU-MANESS-F10S22G2
6 Mitglieder
20 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 4
Letzte 30 Tage: 21
Insgesamt: 4,480
