Zum Hauptinhalt wechseln
Disassembling IBM ThinkPad A30 Upper Case
Was du brauchst
  1. Disassembling IBM ThinkPad A30 Upper Case, Battery: Schritt 1, Bild 1 von 2 Disassembling IBM ThinkPad A30 Upper Case, Battery: Schritt 1, Bild 2 von 2
    • Flip the ThinkPad over so that it is upside down.
    • Slide the highlighted tab to the left.
    • With your finger on the tab, remove the battery by lifting it upwards away from the laptop.
    Frag FixBot
    Kommentar hinzufügen
  2. Disassembling IBM ThinkPad A30 Upper Case, Hard Drive: Schritt 2, Bild 1 von 3 Disassembling IBM ThinkPad A30 Upper Case, Hard Drive: Schritt 2, Bild 2 von 3 Disassembling IBM ThinkPad A30 Upper Case, Hard Drive: Schritt 2, Bild 3 von 3
    • Remove the highlighted screw with a Phillips #1 screwdriver.
    • Pull the hard drive out.
    Frag FixBot
  3. Disassembling IBM ThinkPad A30 Upper Case, Upper Case: Schritt 3, Bild 1 von 1
    • Make sure the laptop is upside down and oriented in the direction shown.
    • Remove the six 16.7mm screws inside the circled holes.
    Frag FixBot
  4. Disassembling IBM ThinkPad A30 Upper Case: Schritt 4, Bild 1 von 1
    • Rotate the ThinkPad so that the hard drive bay is facing you.
    • Remove the black cover to reveal a 14.8mm screw.
    • Remove the uncovered screw with a Phillips #0 screwdriver.
    Frag FixBot
  5. Disassembling IBM ThinkPad A30 Upper Case: Schritt 5, Bild 1 von 2 Disassembling IBM ThinkPad A30 Upper Case: Schritt 5, Bild 2 von 2
    • Flip the ThinkPad over and open the LCD panel.
    • Pry apart the keyboard with a plastic opening tool or with your fingers.
    Frag FixBot
  6. Disassembling IBM ThinkPad A30 Upper Case: Schritt 6, Bild 1 von 3 Disassembling IBM ThinkPad A30 Upper Case: Schritt 6, Bild 2 von 3 Disassembling IBM ThinkPad A30 Upper Case: Schritt 6, Bild 3 von 3
    • Be careful not to pull out the keyboard carelessly; there is a connector underneath it!
    • Lift the front end of the keyboard as shown.
    • Using your fingers, remove the black film cover.
    Frag FixBot
  7. Disassembling IBM ThinkPad A30 Upper Case: Schritt 7, Bild 1 von 3 Disassembling IBM ThinkPad A30 Upper Case: Schritt 7, Bild 2 von 3 Disassembling IBM ThinkPad A30 Upper Case: Schritt 7, Bild 3 von 3
    • Locate the connector attached to the motherboard.
    • Disconnect the ribbon cable by removing the connector.
    Frag FixBot
  8. Disassembling IBM ThinkPad A30 Upper Case: Schritt 8, Bild 1 von 2 Disassembling IBM ThinkPad A30 Upper Case: Schritt 8, Bild 2 von 2
    • Lift and remove the keyboard.
    • Remove the two 5.6mm screws.
    • Remove the 16.7mm screw.
    Frag FixBot
  9. Disassembling IBM ThinkPad A30 Upper Case: Schritt 9, Bild 1 von 3 Disassembling IBM ThinkPad A30 Upper Case: Schritt 9, Bild 2 von 3 Disassembling IBM ThinkPad A30 Upper Case: Schritt 9, Bild 3 von 3
    • You will need to use a little force. Be wary of the tabs.
    • Pry off the upper case with your hands.
    Frag FixBot
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
Alan
380 Reputation
6 Anleitungen geschrieben
Cal Poly, Team 4-44, Amido Fall 2010 Mitglied von Cal Poly, Team 4-44, Amido Fall 2010
CPSU-AMIDO-F10S4G44
4 Mitglieder
26 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 36
Insgesamt: 2,608
