Zum Hauptinhalt wechseln
Disassembling InFocus LP435Z External Shell
Was du brauchst
  1. Disassembling InFocus LP435Z External Shell, External Shell: Schritt 1, Bild 1 von 2 Disassembling InFocus LP435Z External Shell, External Shell: Schritt 1, Bild 2 von 2
    • Place the projector on its back (buttons down) with the lens facing away from you.
    • Remove the two 84mm screws in the upper left and right corners of the projector using the Phillips #2 screwdriver.
    • Remove the remaining three 8.5mm screws using the Phillips #1 screwdriver.
    Frag FixBot
    Kommentar hinzufügen
  2. Disassembling InFocus LP435Z External Shell: Schritt 2, Bild 1 von 2 Disassembling InFocus LP435Z External Shell: Schritt 2, Bild 2 von 2
    • Use the plastic opening tools to push down the clips holding the lamp cover in place, and remove it.
    • There is no lamp assembly in the projector used in this guide, yours may appear different.
    Frag FixBot
  3. Disassembling InFocus LP435Z External Shell: Schritt 3, Bild 1 von 2 Disassembling InFocus LP435Z External Shell: Schritt 3, Bild 2 von 2
    • Remove the two 8.5mm rear screws holding the rear case plate to the projector using the Phillips #1 screwdriver.
    • Pull the rear plate straight off and set it aside.
    Frag FixBot
  4. Disassembling InFocus LP435Z External Shell: Schritt 4, Bild 1 von 3 Disassembling InFocus LP435Z External Shell: Schritt 4, Bild 2 von 3 Disassembling InFocus LP435Z External Shell: Schritt 4, Bild 3 von 3
    • Flip the projector over and turn around so that the lens faces you.
    • Twist the gray zoom adjustment ring clockwise and extend the lens all the way out, and then slide the zoom adjustment ring all the way towards the end of the lens as far as it will go.
    • Slide the front case plate towards the loosened zoom adjustment ring, until the top plate of the projector is freed from underneath the lip of the front case plate.
    • The front case plate will not come all the way off due to the zoom adjustment ring obstructing it. It will merely slide forward a bit.
    Frag FixBot
  5. Disassembling InFocus LP435Z External Shell: Schritt 5, Bild 1 von 2 Disassembling InFocus LP435Z External Shell: Schritt 5, Bild 2 von 2
    • Lift away the top case plate and set it aside.
    Frag FixBot
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
Cal Poly, Team 20-3, Maness Winter 2013 Mitglied von Cal Poly, Team 20-3, Maness Winter 2013
CPSU-MANESS-W13S20G3
4 Mitglieder
7 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 5
Letzte 30 Tage: 41
Insgesamt: 1,602
