Zum Hauptinhalt wechseln
Disassembling Nokia 2366i Keypad
Was du brauchst
    1. Disassembling Nokia 2366i Keypad, Battery: Schritt 1, Bild 1 von 2 Disassembling Nokia 2366i Keypad, Battery: Schritt 1, Bild 2 von 2
      • Turn off the phone.
      • Position the phone so that the back side is in view.
      Frag FixBot
      Kommentar hinzufügen
    2. Disassembling Nokia 2366i Keypad: Schritt 2, Bild 1 von 1
      • Apply pressure on the cover while simultaneously sliding the cover downward.
      • Remove the back battery cover.
      Frag FixBot
    3. Disassembling Nokia 2366i Keypad: Schritt 3, Bild 1 von 3 Disassembling Nokia 2366i Keypad: Schritt 3, Bild 2 von 3 Disassembling Nokia 2366i Keypad: Schritt 3, Bild 3 von 3
      • Insert the spudger between the base of the phone and the phone battery.
      • Position the phone so that the battery won't fall out of the phone.
      • Carefully lift the battery out of the phone.
      • The battery lifts out of the phone easily.
      Frag FixBot
    1. Disassembling Nokia 2366i Keypad, Rear Case: Schritt 4, Bild 1 von 2 Disassembling Nokia 2366i Keypad, Rear Case: Schritt 4, Bild 2 von 2
      • Use a Phillips #00 screwdriver or your fingers to remove the rubber tabs at top back of the phone.
      Frag FixBot
    2. Disassembling Nokia 2366i Keypad: Schritt 5, Bild 1 von 2 Disassembling Nokia 2366i Keypad: Schritt 5, Bild 2 von 2
      • Remove four 5mm screws from the back of the phone using a T6 Torx screwdriver:
      • 2 screws at the bottom
      • 2 screws at the top
      Frag FixBot
    3. Disassembling Nokia 2366i Keypad: Schritt 6, Bild 1 von 2 Disassembling Nokia 2366i Keypad: Schritt 6, Bild 2 von 2
      • Rotate the phone clockwise so the edge is facing you.
      • Insert the spudger in tabs between the outer casing and the inside frame.
      • Slide the spudger upwards.
      • This will remove the rear case of the phone.
      Frag FixBot
    4. Disassembling Nokia 2366i Keypad: Schritt 7, Bild 1 von 1
      • The phone should now be in two different sections.
      • 1) The rear case of the phone.
      • 2) The motherboard and the rest of the phone.
      Frag FixBot
    1. Disassembling Nokia 2366i Keypad, Motherboard: Schritt 8, Bild 1 von 2 Disassembling Nokia 2366i Keypad, Motherboard: Schritt 8, Bild 2 von 2
      • Use the spudger to lift off the yellow clip near the top right corner of the motherboard.
      Frag FixBot
    2. Disassembling Nokia 2366i Keypad: Schritt 9, Bild 1 von 2 Disassembling Nokia 2366i Keypad: Schritt 9, Bild 2 von 2
      • Rotate the phone counterclockwise so that the edge is facing you.
      • Use the spudger to lift the motherboard out of the base of the phone.
      • Remove the motherboard from the base of the phone.
      Frag FixBot
    1. Disassembling Nokia 2366i Keypad, Keypad: Schritt 10, Bild 1 von 1
      • Place key pad in view.
      Frag FixBot
    2. Disassembling Nokia 2366i Keypad: Schritt 11, Bild 1 von 2 Disassembling Nokia 2366i Keypad: Schritt 11, Bild 2 von 2
      • Use your fingers to remove the keypad by carefully pulling from the top of the phone towards the bottom of the phone.
      Frag FixBot
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
Cal Poly, Team 1-14, Amido Winter 2011 Mitglied von Cal Poly, Team 1-14, Amido Winter 2011
CPSU-AMIDO-W11S1G14
5 Mitglieder
36 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 24
Insgesamt: 1,255
