Zum Hauptinhalt wechseln
Disassembling Nokia 3395 Inner Components
Was du brauchst
  1. Disassembling Nokia 3395 Inner Components, Back Case: Schritt 1, Bild 1 von 3 Disassembling Nokia 3395 Inner Components, Back Case: Schritt 1, Bild 2 von 3 Disassembling Nokia 3395 Inner Components, Back Case: Schritt 1, Bild 3 von 3
    • Turn the phone off.
    • Hold the phone, and gently press the white button located at the bottom of the phone.
    • While pressing the button, slide the back plate upwards, opening the plate.
    Frag FixBot
    Kommentar hinzufügen
  2. Disassembling Nokia 3395 Inner Components, Battery: Schritt 2, Bild 1 von 2 Disassembling Nokia 3395 Inner Components, Battery: Schritt 2, Bild 2 von 2
    • Locate grey buttons beneath battery (shown).
    • Spread buttons simultaneously away from each other and the battery will pop out.
    • Remove battery from phone.
    Frag FixBot
  3. Disassembling Nokia 3395 Inner Components, Front Case: Schritt 3, Bild 1 von 2 Disassembling Nokia 3395 Inner Components, Front Case: Schritt 3, Bild 2 von 2
    • Push the two black buttons on the side with your thumbs forward. This will release the front faceplate.
    • Flip over the device, and pry the faceplate away.
    Frag FixBot
  4. Disassembling Nokia 3395 Inner Components, Screen: Schritt 4, Bild 1 von 2 Disassembling Nokia 3395 Inner Components, Screen: Schritt 4, Bild 2 von 2
    • Remove six T6 screws.
    Frag FixBot
  5. Disassembling Nokia 3395 Inner Components: Schritt 5, Bild 1 von 2 Disassembling Nokia 3395 Inner Components: Schritt 5, Bild 2 von 2
    • Insert spudger between screen assembly and phone body.
    • Spread apart as shown. Avoid damaging the screen assembly by removing the screen slowly.
    Frag FixBot
  6. Disassembling Nokia 3395 Inner Components, Logic Board: Schritt 6, Bild 1 von 2 Disassembling Nokia 3395 Inner Components, Logic Board: Schritt 6, Bild 2 von 2
    • Remove logic board as shown.
    Frag FixBot
  7. Disassembling Nokia 3395 Inner Components, Inner Components: Schritt 7, Bild 1 von 1
    • Use the following legend to locate each component:
    • Microphone/power assembly.
    • Vibrating unit.
    • SIM card reader.
    • Audio speaker.
    • Power toggle button.
    • Battery connector.
    Frag FixBot
  8. Disassembling Nokia 3395 Inner Components: Schritt 8, Bild 1 von 2 Disassembling Nokia 3395 Inner Components: Schritt 8, Bild 2 von 2
    • Insert spudger between power assembly/micro-phone and phone body.
    • Pry as shown and remove the power assembly/microphone.
    Frag FixBot
  9. Disassembling Nokia 3395 Inner Components: Schritt 9, Bild 1 von 1
    • Once located, the following components are easily removed by pulling them out with your hand.
    • Vibrating unit.
    • SIM card reader.
    • Audio speaker.
    Frag FixBot
  10. Disassembling Nokia 3395 Inner Components: Schritt 10, Bild 1 von 2 Disassembling Nokia 3395 Inner Components: Schritt 10, Bild 2 von 2
    • Audio speaker.
    Frag FixBot
  11. Disassembling Nokia 3395 Inner Components: Schritt 11, Bild 1 von 2 Disassembling Nokia 3395 Inner Components: Schritt 11, Bild 2 von 2
    • SIM card reader.
    Frag FixBot
  12. Disassembling Nokia 3395 Inner Components: Schritt 12, Bild 1 von 2 Disassembling Nokia 3395 Inner Components: Schritt 12, Bild 2 von 2
    • Vibrating unit.
    Frag FixBot
  13. Disassembling Nokia 3395 Inner Components: Schritt 13, Bild 1 von 2 Disassembling Nokia 3395 Inner Components: Schritt 13, Bild 2 von 2
    Frag FixBot
  14. Disassembling Nokia 3395 Inner Components: Schritt 14, Bild 1 von 2 Disassembling Nokia 3395 Inner Components: Schritt 14, Bild 2 von 2
    Frag FixBot
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
Cal Poly, Team 30-41, Garner Spring 2010 Mitglied von Cal Poly, Team 30-41, Garner Spring 2010
CPSU-GARNER-S10S30G41
4 Mitglieder
23 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 8
Letzte 30 Tage: 41
Insgesamt: 3,369
