Zum Hauptinhalt wechseln
Disassembling Optoma HD20 Cover
Was du brauchst
  1. Disassembling Optoma HD20 Cover, Disassembling Optoma HD20 Cover: Schritt 1, Bild 1 von 2 Disassembling Optoma HD20 Cover, Disassembling Optoma HD20 Cover: Schritt 1, Bild 2 von 2
    • Twist the focal cap clockwise until it is fully extended.
    • Remove the focal cap by pulling it straight out.
    Frag FixBot
    Kommentar hinzufügen
  2. Disassembling Optoma HD20 Cover: Schritt 2, Bild 1 von 1
    • Use a Phillips #1 screwdriver to remove the three 7.5mm screws on the bottom of the device.
    Frag FixBot
  3. Disassembling Optoma HD20 Cover: Schritt 3, Bild 1 von 1
    • Use a plastic opening tool to gently pry the top cover off of the device.
    • It is easier to pry off the cover from the back side just above the HDMI ports.
    Frag FixBot
  4. Disassembling Optoma HD20 Cover: Schritt 4, Bild 1 von 1
    • When removing the cover, be cautious of the ribbon connecting the top buttons to the main circuit board. The ribbon must be disconnected before proceeding.
    • Remove the ribbon by disconnecting it from the main circuit board.
    • Lift up the clip holding it down and pull the ribbon out.
    Frag FixBot
Abschluss
9 weitere Personen haben diese Anleitung absolviert.
Trever
1.282 Reputation
6 Anleitungen geschrieben
Cal Poly, Team 21-23, Maness Winter 2015 Mitglied von Cal Poly, Team 21-23, Maness Winter 2015
CPSU-MANESS-W15S21G23
4 Mitglieder
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 7
Letzte 30 Tage: 38
Insgesamt: 3,819
