Zum Hauptinhalt wechseln
Disassembling Samsung Refrigerator RF4287HA** Door
Was du brauchst
  1. Disassembling Samsung Refrigerator RF4287HA** Door, Remove Cap Top: Schritt 1, Bild 1 von 1
    • With the door open, use a flathead screwdriver to remove the "Cap Top Table"
    • Be gentle and take care not to scratch or damage the plastic parts.
  2. Disassembling Samsung Refrigerator RF4287HA** Door, Door Disassembly: Schritt 2, Bild 1 von 1
    • Remove the 3 screws from the top that hold down the "Top Table"
    • Remove the Top Table
  3. Disassembling Samsung Refrigerator RF4287HA** Door, Left Door Hinge Disconnect: Schritt 3, Bild 1 von 3 Disassembling Samsung Refrigerator RF4287HA** Door, Left Door Hinge Disconnect: Schritt 3, Bild 2 von 3 Disassembling Samsung Refrigerator RF4287HA** Door, Left Door Hinge Disconnect: Schritt 3, Bild 3 von 3
    • Disconnect the electrical connector located above the upper left door hinge.
    • To disconnect the connector, press the raised end of the white part while pulling out.
    • Make sure to unplug the appliance before disconnecting anything.
    • Disconnect the water tube by pulling the tube fitting out away from the white plastic connector.
  4. Disassembling Samsung Refrigerator RF4287HA** Door, Left Door Hinge Disconnect (Continued): Schritt 4, Bild 1 von 1
    • Using a Philips Head Screwdriver, remove the grounding screws.
    • Use a 10mm Socket Wrench to remove the 3 hex bolts.
  5. Disassembling Samsung Refrigerator RF4287HA** Door, Right Door Hinge: Schritt 5, Bild 1 von 1
    • Disconnect the LED Housing using a Philips Head Screwdriver
    • Remove the ground screws using a Philips Head Screwdriver
    • Remove the 3 HEX bolts using a 10mm socket wrench.
  6. Disassembling Samsung Refrigerator RF4287HA** Door, Door Removal: Schritt 6, Bild 1 von 2 Disassembling Samsung Refrigerator RF4287HA** Door, Door Removal: Schritt 6, Bild 2 von 2
    • Remove the lower left and right door hinges using a Philips Head Screwdriver. Use a 10mm wrench to remove the 2 flathead screws.
    • To remove the door, lift it straight up.
Abschluss
Matt Zieminski
46.266 Reputation
28 Anleitungen geschrieben
iFixit Mitglied von iFixit
Staff
120 Mitglieder
20.186 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 6
Letzte 30 Tage: 16
Insgesamt: 353
