Zum Hauptinhalt wechseln
Disassembling Wii Balance Board
Was du brauchst
  1. Disassembling Wii Balance Board, Floor Unit: Schritt 1, Bild 1 von 1
    • Unscrew these #1 Philips screws, and leave them in the plastic foot holders.
    Frag FixBot
    Kommentar hinzufügen
  2. Disassembling Wii Balance Board: Schritt 2, Bild 1 von 1
    • Remove the foot holders and place them on the side
    Frag FixBot
  3. Disassembling Wii Balance Board: Schritt 3, Bild 1 von 1
    • Remove the four feet and place them on the side
    Frag FixBot
  4. Disassembling Wii Balance Board: Schritt 4, Bild 1 von 1
    • Remove these #1 Philips screws, and leave them in their counterbores
    Frag FixBot
  5. Disassembling Wii Balance Board: Schritt 5, Bild 1 von 1
    • Lift grey shell off and place to the side to reveal:
    • ADC and Logic board
    • Bluetooth module
    • Strain gauges
    • Battery holder
    Frag FixBot
  6. Disassembling Wii Balance Board: Schritt 6, Bild 1 von 1
    • The ADC and Logic board contains:
    • Bluetooth module
    • Power button connector
    • Battery and sync button connector
    • Strain gauge wheatstone bridge connections
    • The topmost connection for each of the four bridge connections is the ground; relative to this, the two middle connections should be at 1.2 VDC, and the bottom should be at 2.7 VDC
    Frag FixBot
Abschluss
15 weitere Personen haben diese Anleitung absolviert.
Pete Marchetto
667 Reputation
2 Anleitungen geschrieben
5 Kommentare zur Anleitung
Great stuff Pete, being able to fix the wifi board got me mucho street cred with " her indoors " and lots of other goodies that go along with that
HENRY - Antwort Teilen
Can I take out the battery box without removing the bottom?
Richard Merchant - Antwort Teilen
No, you can't. You will have to follow this procedure completely.
paulo lima - Antwort Teilen
Thank you! I was able to fix our 10 year old balance board.
the kids think I’m a roakstar, for now anyway.
lisadubya - Antwort Teilen
is there schematics for the power pcb
Josué Hernandez - Antwort Teilen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 22
Letzte 30 Tage: 93
Insgesamt: 13,776
