Zum Hauptinhalt wechseln
Disassembly Guide
Was du brauchst
    1. Disassembly Guide, Battery: Schritt 1, Bild 1 von 3 Disassembly Guide, Battery: Schritt 1, Bild 2 von 3 Disassembly Guide, Battery: Schritt 1, Bild 3 von 3
      • Locate the battery housing cover on the bottom of your camera.
      • Place a finger on the textured portion of the battery housing cover.
      • Slide the cover in the direction that the arrow is pointing.
      Frag FixBot
      Kommentar hinzufügen
    2. Disassembly Guide: Schritt 2, Bild 1 von 2 Disassembly Guide: Schritt 2, Bild 2 von 2
      • Use your finger to pivot the orange tab away from the battery.
      Frag FixBot
    3. Disassembly Guide: Schritt 3, Bild 1 von 1
      • Pull the battery out of the housing with your fingers.
      Frag FixBot
    1. Disassembly Guide, Motherboard: Schritt 4, Bild 1 von 2 Disassembly Guide, Motherboard: Schritt 4, Bild 2 von 2
      • Remove the two 4mm Hex screws that connect the grip to the camera with a Hex head screwdriver.
      • Remove the two Phillips screws to the left of the hex screws with a Phillips head screwdriver:
      • One 2mm screw
      • One 3mm screw
      • Remove the grip from the front of the camera by pulling it away from the lens and then away from the camera.
      Frag FixBot
    2. Disassembly Guide: Schritt 5, Bild 1 von 1
      • Remove the following three Philips screws from the flash release side of the camera with a Philips Head screwdriver:
      • One 2.5mm screw
      • One 4.5mm screw
      • One 1.75mm screw
      Frag FixBot
    3. Disassembly Guide: Schritt 6, Bild 1 von 1
      • Remove the following three Philips screws from the bottom of the camera with a Philips Head screwdriver:
      • One 3.25mm screw
      • One 2.5mm screw
      • One 2.75mm screw
      Frag FixBot
    4. Disassembly Guide: Schritt 7, Bild 1 von 2 Disassembly Guide: Schritt 7, Bild 2 von 2
      • Rotate the LCD screen away from the camera.
      Frag FixBot
    5. Disassembly Guide: Schritt 8, Bild 1 von 1
      • Remove the following four Phillips screws securing the back panel with a Philips Head screwdriver:
      • Two 3 mm screws
      • One 2mm screw
      • One 2.5 mm screw
      Frag FixBot
    6. Disassembly Guide: Schritt 9, Bild 1 von 1
      • Lift the back casing up far enough to expose the ribbon cables.
      Frag FixBot
    7. Disassembly Guide: Schritt 10, Bild 1 von 2 Disassembly Guide: Schritt 10, Bild 2 von 2
      • Use a plastic spudger to gently release the locking tab holding the ribbon cable, closest to the edge of the camera, in place.
      • Repeat this process for the second ribbon cable to the right.
      • Carefully lift the back casing away from the camera.
      Frag FixBot
    8. Disassembly Guide: Schritt 11, Bild 1 von 1
      Frag FixBot
    9. Disassembly Guide: Schritt 12, Bild 1 von 2 Disassembly Guide: Schritt 12, Bild 2 von 2
      • Remove the five Phillips screws that are attached to the copper plate with a Philips Head screwdriver:
      • Two 3mm screws
      • Two 1.5mm screws
      • One 4mm screw
      • Lift the copper plate away from the camera.
      Frag FixBot
    10. Disassembly Guide: Schritt 13, Bild 1 von 3 Disassembly Guide: Schritt 13, Bild 2 von 3 Disassembly Guide: Schritt 13, Bild 3 von 3
      • Remove the following three Phillips screws securing the silver plate with a Philips Head screwdriver:
      • Two 2.9mm screws on the front of the camera
      • One 1.8mm screw on the bottom of the camera
      • Lift the silver plate away from the camera.
      Frag FixBot
    11. Disassembly Guide: Schritt 14, Bild 1 von 2 Disassembly Guide: Schritt 14, Bild 2 von 2
      • Use the plastic spudger to lift up both sides of the ribbon cable from its connector pins.
      • The male end is on the left and the female end is on the right. The right side of the cable is notched.
      Frag FixBot
    12. Disassembly Guide: Schritt 15, Bild 1 von 3 Disassembly Guide: Schritt 15, Bild 2 von 3 Disassembly Guide: Schritt 15, Bild 3 von 3
      • Use the flat end of the plastic spudger to rotate the black plastic locking tab towards the ribbon cable.
      • Insert the pointed end of the plastic spudger into a small hole on the side of the ribbon cable and pull the ribbon cable out of its housing.
      • Use the flat end of the plastic spudger to pry the ribbon cable connector from the motherboard.
      • Both ribbon cables should be removed after this step.
      Frag FixBot
    13. Disassembly Guide: Schritt 16, Bild 1 von 2 Disassembly Guide: Schritt 16, Bild 2 von 2
      • Release the flash by sliding the flash release towards the lens.
      • The flash release is located on the side of the camera closest to the lens.
      Frag FixBot
    14. Disassembly Guide: Schritt 17, Bild 1 von 2 Disassembly Guide: Schritt 17, Bild 2 von 2
      • Remove the following two Phillips screws from the flash cavity with a Philips Head screwdriver:
      • Remove the 2mm screw to the right of the flash.
      • Remove the 2.5mm screw to the left of the flash.
      Frag FixBot
    15. Disassembly Guide: Schritt 18, Bild 1 von 2 Disassembly Guide: Schritt 18, Bild 2 von 2
      • Remove the 2.5mm Phillips screw from the front plate with a Phillips head screwdriver.
      • Pull up on the top portion of the camera to separate the top casing from the camera body.
      • Make sure the flash is up. Otherwise the top casing will not release.
      Frag FixBot
    16. Disassembly Guide: Schritt 19, Bild 1 von 2 Disassembly Guide: Schritt 19, Bild 2 von 2
      • Remove the 3.5mm Phillips screw from the grey tab on the top of the camera with a Philips Head screwdriver.
      • Rotate the camera so the back panel is facing you.
      • Remove the 1.4mm Phillips screw from the sliver tab near the top of the camera with a Philips Head screwdriver.
      Frag FixBot
    17. Disassembly Guide: Schritt 20, Bild 1 von 2 Disassembly Guide: Schritt 20, Bild 2 von 2
      • Use the flat end of the plastic spudger to release the plastic retaining clip on the side plate closest to the lens.
      • Rotate the side plate closest to the lens toward the lens of the camera and then pull the plate away from the camera.
      Frag FixBot
    18. Disassembly Guide: Schritt 21, Bild 1 von 3 Disassembly Guide: Schritt 21, Bild 2 von 3 Disassembly Guide: Schritt 21, Bild 3 von 3
      In diesem Schritt verwendetes Werkzeug:
      • Release the plastic locking tab of the upper ribbon cable with the plastic spudger.
      • Pull the top ribbon cable from its mount with the fine tip metal tweezers.
      • Remove the bottom ribbon cable with the fine tip metal tweezers by pulling it toward the flash switch side of the camera.
      • The bottom ribbon cable does not have a locking tab; it simply slides in and out.
      Frag FixBot
    19. Disassembly Guide: Schritt 22, Bild 1 von 1
      • Pull the front plate off the camera body.
      • It should slide off easily. If it does not, ensure that all screws and ribbon cables from previous steps have been removed or disconnected.
      Frag FixBot
    20. Disassembly Guide: Schritt 23, Bild 1 von 1
      • Remove the rubber dust cover from the camera by moving the hooks away from the three prongs holding them in place and then pulling the cover away from the camera.
      Frag FixBot
    21. Disassembly Guide: Schritt 24, Bild 1 von 2 Disassembly Guide: Schritt 24, Bild 2 von 2
      • Remove the following two Phillips screws from the side of the camera with the three connector ports with a Phillips head screwdriver:
      • One 2.5mm screw
      • One 3.3mm screw
      • Pull the metal shield away from the camera.
      Frag FixBot
    22. Disassembly Guide: Schritt 25, Bild 1 von 3 Disassembly Guide: Schritt 25, Bild 2 von 3 Disassembly Guide: Schritt 25, Bild 3 von 3
      • Use the plastic spudger to remove the ribbon cable from the motherboard by placing the spudger under the ribbon cable connector and pulling up.
      • Remove the 2.8mm screw from the motherboard.
      • Do not try to remove the motherboard from the camera yet.
      • Carefully rotate the motherboard upward.
      • Use the plastic spudger to remove the ribbon cable from the bottom of the motherboard by placing the spudger under the ribbon cable connector and pulling up.
      Frag FixBot
    23. Disassembly Guide: Schritt 26, Bild 1 von 1
      • Lift the motherboard away from the camera.
      Frag FixBot
    1. Disassembly Guide, Lens: Schritt 27, Bild 1 von 3 Disassembly Guide, Lens: Schritt 27, Bild 2 von 3 Disassembly Guide, Lens: Schritt 27, Bild 3 von 3
      • Lay the camera on a flat surface while performing these steps because removing the frame causes the camera to fall apart.
      • Remove the four 4.25mm Philips screws from the silver frame that surrounds the lens of the camera with a Philips Head screwdriver.
      • Remove the frame by lifting straight up.
      Frag FixBot
    2. Disassembly Guide: Schritt 28, Bild 1 von 1
      • Separate the lens from the other components of the camera.
      Frag FixBot
    1. Disassembly Guide, Disassembly Guide: Schritt 29, Bild 1 von 1
      • You have disassembled the Canon PowerShot G1 X Mark II!
      Frag FixBot
Abschluss
7 weitere Personen haben diese Anleitung absolviert.
Cal Poly, Team 70-2, Forte Winter 2016 Mitglied von Cal Poly, Team 70-2, Forte Winter 2016
CPSU-FORTE-W16S70G2
4 Mitglieder
4 Anleitungen geschrieben
5 Kommentare zur Anleitung
Surely these are JIS screws not Phillips. A Phillips screwdriver will chew the heads up.
maico61 - Antwort Teilen
I have an LCD display problem and would like to disassemble it, the guide does not cover anything to do with the LDC assembly, otherwise a very good guide. I’ll attempt it anyway once I feel like a risk.
Alan Cattalon - Antwort Teilen
Fabuloso. La pantalla de mi camara canon gx1 cuando la invertias se apagaba. Lo que he hecho fue comprar un cable ribbon nuevo en aliexpress y substituirlo. Asunto arreglado por 7euros.
En este tutorial, falta como desmontar la pantalla. Para hacerlo debes retirar los tornillos de la pantalla con delicadeza, despegar el cable con delicadeza y montar la pantalla otra vez.
MIGUEL A. MARTINEZ GOMEZ - Antwort Teilen
hola miguel angel, cual es ese cable? podrias enlazarlo, mi pantalla da fallos y debe ser ese ribbon. gracias!
alvarezrodriguezrc - Antwort Teilen
Thanks for this great guide ! I need to disassemble and clean the external flash connector in the top portion of the camera because of some dirt and even corrosion - I found no way how to do this, I removed all screws but I was not able to remove the metallic structure. Any idea to take this apart ? thanks in advance...
M Df - Antwort Teilen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 12
Letzte 30 Tage: 66
Insgesamt: 11,928
