Zum Hauptinhalt wechseln
Doss E-GO II Button Receptors Replacement
Was du brauchst
  1. Doss E-GO II Button Receptors Replacement, Button Receptors: Schritt 1, Bild 1 von 3 Doss E-GO II Button Receptors Replacement, Button Receptors: Schritt 1, Bild 2 von 3 Doss E-GO II Button Receptors Replacement, Button Receptors: Schritt 1, Bild 3 von 3
    • Peel the backing off of the speaker.
    • Remove eight 7.9 mm screws using the Phillips #00 screwdriver.
    • Gently pull apart the grille on the sides of the speaker.
  2. Doss E-GO II Button Receptors Replacement: Schritt 2, Bild 1 von 2 Doss E-GO II Button Receptors Replacement: Schritt 2, Bild 2 von 2
    • Remove seven 8 mm screws using a Phillips #00 screwdriver.
    • Remove six 7.3 mm screws using a Phillips #00 screwdriver.
  3. Doss E-GO II Button Receptors Replacement: Schritt 3, Bild 1 von 3 Doss E-GO II Button Receptors Replacement: Schritt 3, Bild 2 von 3 Doss E-GO II Button Receptors Replacement: Schritt 3, Bild 3 von 3
    • Apply a bead of flux.
    • Press the soldering iron tip firmly to melt the solder.
    • If you heat the circuit board constantly for more than 10 seconds, the excessive heat may damage the board.
    • Use tweezers to remove the receptor.
  4. Doss E-GO II Button Receptors Replacement: Schritt 4, Bild 1 von 1
    • Use a small piece of solder to attach a new receptor.
    • Press the tip 2 seconds on each corner to attach the receptor to the board.
Abschluss
Natalie
355 Reputation
2 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 5
Letzte 30 Tage: 20
Insgesamt: 168
