Zum Hauptinhalt wechseln
DualSense Controller v2 Adaptive Trigger Replacement
Was du brauchst
  1. DualSense Controller v2 Adaptive Trigger Replacement, Unclip the right end of the middle trim: Schritt 1, Bild 1 von 2 DualSense Controller v2 Adaptive Trigger Replacement, Unclip the right end of the middle trim: Schritt 1, Bild 2 von 2
    • Disconnect and power down your controller before you begin.
    • Insert an opening pick underneath the middle trim at the bottom-right corner of the controller to release the clips securing it to the case.
  2. DualSense Controller v2 Adaptive Trigger Replacement, Unclip the lower-right edge of the middle trim: Schritt 2, Bild 1 von 3 DualSense Controller v2 Adaptive Trigger Replacement, Unclip the lower-right edge of the middle trim: Schritt 2, Bild 2 von 3 DualSense Controller v2 Adaptive Trigger Replacement, Unclip the lower-right edge of the middle trim: Schritt 2, Bild 3 von 3
    • Slide the opening pick along the lower-right edge of the middle trim to release the clips securing it to the case.
  3. DualSense Controller v2 Adaptive Trigger Replacement, Unclip the left end of the middle trim: Schritt 3, Bild 1 von 2 DualSense Controller v2 Adaptive Trigger Replacement, Unclip the left end of the middle trim: Schritt 3, Bild 2 von 2
    • Insert an opening pick underneath the middle trim at the bottom-left corner of the controller to release the clips securing it to the case.
  4. DualSense Controller v2 Adaptive Trigger Replacement, Unclip the lower-left edge of the middle trim: Schritt 4, Bild 1 von 3 DualSense Controller v2 Adaptive Trigger Replacement, Unclip the lower-left edge of the middle trim: Schritt 4, Bild 2 von 3 DualSense Controller v2 Adaptive Trigger Replacement, Unclip the lower-left edge of the middle trim: Schritt 4, Bild 3 von 3
    • Slide the opening pick along the lower-left edge of the middle trim to release the clips securing it to the case.
  5. DualSense Controller v2 Adaptive Trigger Replacement, Remove the middle trim: Schritt 5, Bild 1 von 3 DualSense Controller v2 Adaptive Trigger Replacement, Remove the middle trim: Schritt 5, Bild 2 von 3 DualSense Controller v2 Adaptive Trigger Replacement, Remove the middle trim: Schritt 5, Bild 3 von 3
    • Use your fingers to lift up the bottom edge of the middle trim to release the remaining clips.
    • Lift the middle trim over the joysticks to remove it.
    • During reassembly, position the middle trim into place and press along all edges to engage the clips securing it to the controller.
  6. DualSense Controller v2 Adaptive Trigger Replacement, Remove the L1 button: Schritt 6, Bild 1 von 3 DualSense Controller v2 Adaptive Trigger Replacement, Remove the L1 button: Schritt 6, Bild 2 von 3 DualSense Controller v2 Adaptive Trigger Replacement, Remove the L1 button: Schritt 6, Bild 3 von 3
    • Insert the flat end of your spudger into the gap above the L1 button.
    • Cover the button with your thumb to prevent it from ejecting across the room.
    • Pry the spudger upward to remove the L1 button.
  7. DualSense Controller v2 Adaptive Trigger Replacement, Remove the R1 button: Schritt 7, Bild 1 von 3 DualSense Controller v2 Adaptive Trigger Replacement, Remove the R1 button: Schritt 7, Bild 2 von 3 DualSense Controller v2 Adaptive Trigger Replacement, Remove the R1 button: Schritt 7, Bild 3 von 3
    • Insert the flat end of your spudger into the gap above the R1 button.
    • Pry the spudger upward to remove the R1 button.
  8. DualSense Controller v2 Adaptive Trigger Replacement, Remove the case screws: Schritt 8, Bild 1 von 1
    • Use a Phillips screwdriver to remove the two 6.5 mm screws securing the bottom corners of the lower case.
  9. DualSense Controller v2 Adaptive Trigger Replacement: Schritt 9, Bild 1 von 1
    • Use a Phillips screwdriver to remove the two 6.5 mm screws behind the L1 and R1 buttons.
  10. DualSense Controller v2 Adaptive Trigger Replacement, Unclip the rear case: Schritt 10, Bild 1 von 3 DualSense Controller v2 Adaptive Trigger Replacement, Unclip the rear case: Schritt 10, Bild 2 von 3 DualSense Controller v2 Adaptive Trigger Replacement, Unclip the rear case: Schritt 10, Bild 3 von 3
    • Use the pointed edge of a spudger to unclip the two clips on either side of the headset jack.
  11. DualSense Controller v2 Adaptive Trigger Replacement, Remove the rear case: Schritt 11, Bild 1 von 2 DualSense Controller v2 Adaptive Trigger Replacement, Remove the rear case: Schritt 11, Bild 2 von 2
    • Use your hands to carefully pull the rear case off of the controller.
    • During reassembly, make sure the red and black vibration motor wires are not pinched between the front and rear case.
  12. DualSense Controller v2 Adaptive Trigger Replacement, Reposition the battery: Schritt 12, Bild 1 von 2 DualSense Controller v2 Adaptive Trigger Replacement, Reposition the battery: Schritt 12, Bild 2 von 2
    • Lift the battery out of its bracket and reposition it to the right for better access to the battery connector.
    • Don't strain the battery cables.
  13. DualSense Controller v2 Adaptive Trigger Replacement, Disconnect the battery: Schritt 13, Bild 1 von 2 DualSense Controller v2 Adaptive Trigger Replacement, Disconnect the battery: Schritt 13, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    • Use a pair of tweezers or your fingers to disconnect the battery from the motherboard.
    • Don't pull on the wires to disconnect the battery.
  14. DualSense Controller v2 Adaptive Trigger Replacement, Remove the battery: Schritt 14, Bild 1 von 1
    • Remove the battery.
  15. DualSense Controller v2 Adaptive Trigger Replacement, Remove the lower microphone: Schritt 15, Bild 1 von 2 DualSense Controller v2 Adaptive Trigger Replacement, Remove the lower microphone: Schritt 15, Bild 2 von 2
    • Use the pointed end of your spudger to remove the lower microphone from its bracket next to the battery.
    • During reassembly, make sure the end of the microphone's ribbon cable is slotted into the bracket.
  16. DualSense Controller v2 Adaptive Trigger Replacement: Schritt 16, Bild 1 von 2 DualSense Controller v2 Adaptive Trigger Replacement: Schritt 16, Bild 2 von 2
    • Grab the lower microphone ribbon cable pull tab with your fingers or a pair of tweezers and disconnect it from the motherboard.
  17. DualSense Controller v2 Adaptive Trigger Replacement, Remove the battery bracket: Schritt 17, Bild 1 von 1
    • Use a Phillips screwdriver to remove the 6.5 mm screw securing the battery bracket.
  18. DualSense Controller v2 Adaptive Trigger Replacement: Schritt 18, Bild 1 von 2 DualSense Controller v2 Adaptive Trigger Replacement: Schritt 18, Bild 2 von 2
    • Lift the battery bracket off of the motherboard.
  19. DualSense Controller v2 Adaptive Trigger Replacement, Disconnect the right trigger assembly: Schritt 19, Bild 1 von 2 DualSense Controller v2 Adaptive Trigger Replacement, Disconnect the right trigger assembly: Schritt 19, Bild 2 von 2
    • Grip the right trigger assembly cable with a pair of tweezers or your fingers and disconnect it from the motherboard.
    • Use the pull tab to disconnect the cable. Don't pull on the cable itself.
    • Don't completely remove the ribbon cable yet.
  20. DualSense Controller v2 Adaptive Trigger Replacement: Schritt 20, Bild 1 von 2 DualSense Controller v2 Adaptive Trigger Replacement: Schritt 20, Bild 2 von 2
    • Grip the right trigger assembly cable with a pair of tweezers or your fingers, and disconnect it from the trigger assembly.
    • Depending on your model controller, the ribbon cable may block the motherboard from coming loose. If so, remove the cable from the trigger assembly.
  21. DualSense Controller v2 Adaptive Trigger Replacement, Disconnect the left trigger assembly: Schritt 21, Bild 1 von 2 DualSense Controller v2 Adaptive Trigger Replacement, Disconnect the left trigger assembly: Schritt 21, Bild 2 von 2
    • Grip the left trigger assembly cable with a pair of tweezers or your fingers to disconnect it from the motherboard.
  22. DualSense Controller v2 Adaptive Trigger Replacement: Schritt 22, Bild 1 von 2 DualSense Controller v2 Adaptive Trigger Replacement: Schritt 22, Bild 2 von 2
    • Grip the left trigger assembly cable with a pair of tweezers or your fingers to disconnect it from the trigger assembly.
  23. DualSense Controller v2 Adaptive Trigger Replacement, Disconnect the upper microphone: Schritt 23, Bild 1 von 2 DualSense Controller v2 Adaptive Trigger Replacement, Disconnect the upper microphone: Schritt 23, Bild 2 von 2
    • Use a pair of tweezers or your fingers to disconnect the upper microphone from the motherboard.
    • If you're not replacing this microphone, don't remove it from the frame.
  24. DualSense Controller v2 Adaptive Trigger Replacement, Disconnect the touchpad: Schritt 24, Bild 1 von 2 DualSense Controller v2 Adaptive Trigger Replacement, Disconnect the touchpad: Schritt 24, Bild 2 von 2
    • Use a pair of tweezers or your fingers to disconnect the touchpad cable from the motherboard.
  25. DualSense Controller v2 Adaptive Trigger Replacement, Lift out the motherboard: Schritt 25, Bild 1 von 3 DualSense Controller v2 Adaptive Trigger Replacement, Lift out the motherboard: Schritt 25, Bild 2 von 3 DualSense Controller v2 Adaptive Trigger Replacement, Lift out the motherboard: Schritt 25, Bild 3 von 3
    • Carefully guide the joysticks through the front case and lift the motherboard out.
    • Don't strain the four soldered wires tethering the motherboard to the vibration motors.
  26. DualSense Controller v2 Adaptive Trigger Replacement, Remove the light guide: Schritt 26, Bild 1 von 3 DualSense Controller v2 Adaptive Trigger Replacement, Remove the light guide: Schritt 26, Bild 2 von 3 DualSense Controller v2 Adaptive Trigger Replacement, Remove the light guide: Schritt 26, Bild 3 von 3
    • Use the pointed end of your spudger to lift the center of the light guide out of the controller.
    • Remove the light guide.
  27. DualSense Controller v2 Adaptive Trigger Replacement, Remove the midframe: Schritt 27, Bild 1 von 1
    • Use your Phillips driver to remove the two 6.5 mm screws securing the midframe to the front case.
  28. DualSense Controller v2 Adaptive Trigger Replacement: Schritt 28, Bild 1 von 3 DualSense Controller v2 Adaptive Trigger Replacement: Schritt 28, Bild 2 von 3 DualSense Controller v2 Adaptive Trigger Replacement: Schritt 28, Bild 3 von 3
    • Carefully lift the midframe and motherboard up and out of the front case.
    • Be careful not to strain the vibrator motor wires.
    • During reassembly, feed the touchpad's ribbon cable back through its rectangular opening in the midframe.
  29. DualSense Controller v2 Adaptive Trigger Replacement, Remove the adaptive triggers: Schritt 29, Bild 1 von 1
    • Use your Phillips screwdriver to remove the four 6.5 mm screws securing the adaptive triggers to the midframe.
    • The adaptive triggers are loose and will fall out of the midframe.
    • During reassembly, verify the conductive membrane is properly aligned by checking the screw holes and alignment posts.
    • Proper alignment of the conductive membrane is essential for button functionality.
  30. DualSense Controller v2 Adaptive Trigger Replacement: Schritt 30, Bild 1 von 2 DualSense Controller v2 Adaptive Trigger Replacement: Schritt 30, Bild 2 von 2
    • Lift the midframe off of the adaptive triggers.
    • Be careful not to pull the vibration motor wires out of the motherboard.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
Sam Omiotek
83.744 Reputation
290 Anleitungen geschrieben
4 Kommentare
Anyone knows where to buy the Adaptive Triggers for this controller model, CFI-ZCT1W? Thanks in advance.
Obel Ortiz - Antwort
This is wrong. Not the instructions for V2 as V2 removed the screws that hold the adaptive triggers so now it's impossible to remove them.
Glen Senecal - Antwort
Does anyone know how to replace the l2 and r2 bumpers? I need to remove for a controller mod
MalicePalace - Antwort
For a BDM-020 controller, extremerate has a video about installing a clicky kit that requires you to take off the trigger caps. They also have mods for other controller versions, so I assume they have videos for those controller variations too.
https://youtu.be/JSpm7piCqgQ?si=SyotXDne...
Lone -
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 20
Letzte 7 Tage: 175
Letzte 30 Tage: 747
Insgesamt: 13,637
