Zum Hauptinhalt wechseln
DualSense Edge zerlegen
Was du brauchst
Videoanleitungen
Abschluss
Um dein Gerät wieder zusammenzubauen, folge den Anweisungen im Videotutorial.
7 weitere Personen haben diese Anleitung absolviert.
en de
100%
Hier starten ›
Arty
34.229 Reputation
110 Anleitungen geschrieben
7 Kommentare zur Anleitung
I'm looking for replacement parts for the back paddle slots of the duelscene edge. My left slot broke and now my paddle just hangs there.
DrewDave - Antwort Teilen
Hey, I'm looking for the same thing did you ever find them?
gboro84 - Antwort Teilen
So I guess this is common issue same here button still works but loose. I actually thought my 5yr old got his hands on it but I’m glad I saw this post to know it wasn’t his fault.
Andrew Lavore - Antwort Teilen
Hello, I recently went on a flight and I believe by controller has received damage while being transported. When I hold the handles of the controller I hear a squeaking noise. I believe it is the face piece of the controller. Should I attempt to warranty the controller or try to disassemble and replace a part that might not be the cause of my issue?
setboy 04 - Antwort Teilen
Extreme rate makes 2 fixes for it
Michael Spinks - Antwort Teilen
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 28
Letzte 7 Tage: 188
Letzte 30 Tage: 936
Insgesamt: 23,176
