Zum Hauptinhalt wechseln
Dymo LabelManager 280 Keyboard Replacement
Was du brauchst
    1. Dymo LabelManager 280 Keyboard Replacement, Rear Case: Schritt 1, Bild 1 von 2 Dymo LabelManager 280 Keyboard Replacement, Rear Case: Schritt 1, Bild 2 von 2
      • Remove battery.
      • Remove the label cassette.
      Frag FixBot
      Kommentar hinzufügen
    2. Dymo LabelManager 280 Keyboard Replacement: Schritt 2, Bild 1 von 2 Dymo LabelManager 280 Keyboard Replacement: Schritt 2, Bild 2 von 2
      • Remove the two rubber feets
      • Remove the 6 screws in the indicated places. These particular screws are 2mm x 8mm Phillips #0 head
      Frag FixBot
    3. Dymo LabelManager 280 Keyboard Replacement: Schritt 3, Bild 1 von 2 Dymo LabelManager 280 Keyboard Replacement: Schritt 3, Bild 2 von 2
      • Use the spudger to take apart the device by insterting it as shown in the picture and twisting it. This should be done all around the device to ensure the two parts split correctly.
      • The keys/buttons highlighted in the second picture fall out easily so be careful. Keep device faced down in order to keep them from falling.
      Frag FixBot
    1. Dymo LabelManager 280 Keyboard Replacement, Keyboard: Schritt 4, Bild 1 von 2 Dymo LabelManager 280 Keyboard Replacement, Keyboard: Schritt 4, Bild 2 von 2
      • Remove the rubber keyboard.
      Frag FixBot
Abschluss
USF Tampa, Team 6-5, Eyestone Spring 2016 Mitglied von USF Tampa, Team 6-5, Eyestone Spring 2016
USFT-EYESTONE-S16S6G5
3 Mitglieder
4 Anleitungen geschrieben
1 Kommentar zur Anleitung
thank god the bottom feet are not glued in. and the tabs are not difficult
Edward Wijntuin - Antwort Teilen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 22
Insgesamt: 1,420
