Zum Hauptinhalt wechseln
Dyson DC39 Origin Cyclone Filter Replacement
Was du brauchst
    1. Dyson DC39 Origin Cyclone Filter Replacement, Bin: Schritt 1, Bild 1 von 3 Dyson DC39 Origin Cyclone Filter Replacement, Bin: Schritt 1, Bild 2 von 3 Dyson DC39 Origin Cyclone Filter Replacement, Bin: Schritt 1, Bild 3 von 3
      • Push down on the gray button located next to the power button to release the bin from the ball housing.
      • Pull the bin away, then up from the ball housing to remove it.
      • If the bin won't fit back into place during re-assembly, you may need to push the grey button again.
      Frag FixBot
      Kommentar hinzufügen
    1. Dyson DC39 Origin Cyclone Filter Replacement, Pre-filter: Schritt 2, Bild 1 von 3 Dyson DC39 Origin Cyclone Filter Replacement, Pre-filter: Schritt 2, Bild 2 von 3 Dyson DC39 Origin Cyclone Filter Replacement, Pre-filter: Schritt 2, Bild 3 von 3
      • Remove the purple pre-filter by pulling it up and out of the bin.
      Frag FixBot
    1. Dyson DC39 Origin Cyclone Filter Replacement, Cyclone Filter: Schritt 3, Bild 1 von 2 Dyson DC39 Origin Cyclone Filter Replacement, Cyclone Filter: Schritt 3, Bild 2 von 2
      • Push down on the red button, located on top of the bin, to release the bottom section of the bin.
      Frag FixBot
    2. Dyson DC39 Origin Cyclone Filter Replacement: Schritt 4, Bild 1 von 1
      • Push the grey button located in between the parts of the red lever to release the clear, bottom section of the bin.
      • The grey button can only be pressed after the bottom section is open.
      Frag FixBot
    3. Dyson DC39 Origin Cyclone Filter Replacement: Schritt 5, Bild 1 von 3 Dyson DC39 Origin Cyclone Filter Replacement: Schritt 5, Bild 2 von 3 Dyson DC39 Origin Cyclone Filter Replacement: Schritt 5, Bild 3 von 3
      • You should notice several notches around the rim of the filter. Slide the plastic opening tool around the rim to release the notches.
      • After releasing all of the notches, pull the filter away from the orange cyclone assembly to remove it from the bin.
      Frag FixBot
Abschluss
3 weitere Personen haben diese Anleitung absolviert.
Cal Poly, Team S23-G6, Livingston Spring 2017 Mitglied von Cal Poly, Team S23-G6, Livingston Spring 2017
CPSU-LIVINGSTON-S17S23G6
3 Mitglieder
12 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 8
Letzte 30 Tage: 69
Insgesamt: 4,076
