Zum Hauptinhalt wechseln
Evercade EXP Buttons Replacement
Was du brauchst
  1. Evercade EXP Buttons Replacement, Faceplate: Schritt 1, Bild 1 von 3 Evercade EXP Buttons Replacement, Faceplate: Schritt 1, Bild 2 von 3 Evercade EXP Buttons Replacement, Faceplate: Schritt 1, Bild 3 von 3
    • Lay the device on a flat surface, with the screen facing the sufrace.
    • Using angled tweezers, remove the six rubber screw covers from the sockets.
    • The covers are all identical, so they do not need to be stored separately from one another.
    Frag FixBot
    Kommentar hinzufügen
  2. Evercade EXP Buttons Replacement: Schritt 2, Bild 1 von 3 Evercade EXP Buttons Replacement: Schritt 2, Bild 2 von 3 Evercade EXP Buttons Replacement: Schritt 2, Bild 3 von 3
    • Using a Phillips #00 screwdriver, remove the six 8 mm screws on the lower case.
    Frag FixBot
  3. Evercade EXP Buttons Replacement: Schritt 3, Bild 1 von 2 Evercade EXP Buttons Replacement: Schritt 3, Bild 2 von 2
    • Flip the device so the screen is facing you.
    • Four hidden retaining clips hold the pieces together even near each corner of the screen.
    • Insert a Jimmy into the seam located between the faceplate and the shell.
    • Move the a Jimmy toward the screen until you find the first clasp. Move the handle of the jimmy tool up to pop the faceplate free from the clasp.
    • Repeat until for each of the four clasps to fully release the faceplate from the shell.
    • Do not use excessive force when moving the Jimmy. The plastic may shear if too much force is applied horizontally, and it may snap if too much vertical force is applied.
    Frag FixBot
  4. Evercade EXP Buttons Replacement: Schritt 4, Bild 1 von 3 Evercade EXP Buttons Replacement: Schritt 4, Bild 2 von 3 Evercade EXP Buttons Replacement: Schritt 4, Bild 3 von 3
    • Flip the faceplate away from the shell carefully. The faceplate is still connected to the motherboard via a ribbon cable.
    • Flip up the locking flap securing the display ribbon cable, then use tweezers to disconnect the ribbon cable.
    • Be careful when separating the faceplate from the shell, the buttons are held in place by the connection, so they may fall out when opening the device.
    Frag FixBot
  5. Evercade EXP Buttons Replacement, Buttons: Schritt 5, Bild 1 von 3 Evercade EXP Buttons Replacement, Buttons: Schritt 5, Bild 2 von 3 Evercade EXP Buttons Replacement, Buttons: Schritt 5, Bild 3 von 3
    • Locate the four circular buttons in a diamond shape on the face plate, the two circular buttons placed next to each other, and the two small oval buttons and a circular button in a row near those in a diamond pattern.
    • Using angled tweezer, gently remove the buttons from the face plate. The buttons may fall out, so be ready to catch any that fall from the device before intended removal.
    • The buttons are held in place with the pressure of the shell and faceplate when closed. They should be removed with a nominal amount of force.
    Frag FixBot
Abschluss
Utah Tech University, Team 1-6, McMurrin Spring 2026 Mitglied von Utah Tech University, Team 1-6, McMurrin Spring 2026
UTAHTECH-MCMURRIN-S26S1G6
3 Mitglieder
7 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 10
Letzte 30 Tage: 46
Insgesamt: 94
