Zum Hauptinhalt wechseln
Flip Video Ultra Power button Replacement
Was du brauchst
  1. Flip Video Ultra Power button Replacement, Power button: Schritt 1, Bild 1 von 1
    • Unlock the battery cover by sliding the switch to the unlock position.
    Frag FixBot
    Kommentar hinzufügen
  2. Flip Video Ultra Power button Replacement: Schritt 2, Bild 1 von 1
    • Remove the battery cover by sliding it down the camera.
    Frag FixBot
  3. Flip Video Ultra Power button Replacement: Schritt 3, Bild 1 von 1
    • Remove the batteries
    Frag FixBot
  4. Flip Video Ultra Power button Replacement: Schritt 4, Bild 1 von 1
    • Slide the black upper casing off from the device.
    Frag FixBot
  5. Flip Video Ultra Power button Replacement: Schritt 5, Bild 1 von 2 Flip Video Ultra Power button Replacement: Schritt 5, Bild 2 von 2
    • Remove the six 1mm screws from the back and upper casing with the Phillips Head screwdriver.
    Frag FixBot
  6. Flip Video Ultra Power button Replacement: Schritt 6, Bild 1 von 1
    • Remove the top casing from the bottom to reveal the inner circuit board.
    Frag FixBot
  7. Flip Video Ultra Power button Replacement: Schritt 7, Bild 1 von 2 Flip Video Ultra Power button Replacement: Schritt 7, Bild 2 von 2
    • When removing the back panel, the rubber buttons will become loose and likely fall off the board. This is normal and can easily placed back on the board once finished.
    • Remove the six 1mm screws with the 1 Phillips head screwdriver.
    Frag FixBot
  8. Flip Video Ultra Power button Replacement: Schritt 8, Bild 1 von 1
    • Gently separate the circuit board from the casing.
    Frag FixBot
  9. Flip Video Ultra Power button Replacement: Schritt 9, Bild 1 von 2 Flip Video Ultra Power button Replacement: Schritt 9, Bild 2 von 2
    • Unscrew the single 1mm screw from USB housing unit.
    Frag FixBot
  10. Flip Video Ultra Power button Replacement: Schritt 10, Bild 1 von 2 Flip Video Ultra Power button Replacement: Schritt 10, Bild 2 von 2
    • Unscrew the 2 1mm screws and gently separate camera wires from plastic casing.
    Frag FixBot
  11. Flip Video Ultra Power button Replacement: Schritt 11, Bild 1 von 1
    • Gently pry out the USB housing unit with the Ifxit Opening Tool.
    Frag FixBot
  12. Flip Video Ultra Power button Replacement: Schritt 12, Bild 1 von 3 Flip Video Ultra Power button Replacement: Schritt 12, Bild 2 von 3 Flip Video Ultra Power button Replacement: Schritt 12, Bild 3 von 3
    • Remove the two 1mm screws and separate the circuit board and camera from the plastic casing.
    Frag FixBot
  13. Flip Video Ultra Power button Replacement: Schritt 13, Bild 1 von 1
    • Unscrew the camera housing unit from the plastic case.
    Frag FixBot
Abschluss
UMass Dartmouth, Team 5-7, Martin Fall 2016 Mitglied von UMass Dartmouth, Team 5-7, Martin Fall 2016
UMASSD-MARTIN-F16S5G7
3 Mitglieder
10 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 27
Insgesamt: 785
