Zum Hauptinhalt wechseln
Garmin Forerunner 405 Button Replacement
Was du brauchst
  1. Garmin Forerunner 405 Button Replacement, Unscrew backing: Schritt 1, Bild 1 von 1
    • Unscrew the four 6.35 mm Torx T5 screws securing the backing of the watch.
    Frag FixBot
    Kommentar hinzufügen
  2. Garmin Forerunner 405 Button Replacement, Separate Component: Schritt 2, Bild 1 von 1
    • Pull the backing off the watch.
    Frag FixBot
  3. Garmin Forerunner 405 Button Replacement, Separate: Schritt 3, Bild 1 von 1
    • Pull the battery wires out from the motherboard slowly.
    Frag FixBot
  4. Garmin Forerunner 405 Button Replacement, Unscrew: Schritt 4, Bild 1 von 1
    • Unscrew one 4 mm philips screw that attaches the motherboard using a PH000 screwdriver.
    • Lift the motherboard out of the watch.
    Frag FixBot
  5. Garmin Forerunner 405 Button Replacement, Pull apart: Schritt 5, Bild 1 von 2 Garmin Forerunner 405 Button Replacement, Pull apart: Schritt 5, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    • Push button in and pinch silver clip with tweezers.
    • Pull silver clip off the pin it is on.
    • Pull out button and replace.
    Frag FixBot
Abschluss
USF Sarasota-Manatee, Team 1-4, Stewart Fall 2014 Mitglied von USF Sarasota-Manatee, Team 1-4, Stewart Fall 2014
USFSM-STEWART-F14S1G4
4 Mitglieder
19 Anleitungen geschrieben
2 Kommentare zur Anleitung
Where to find repair button for FR60? Can it be 3d printed? Garmin asks too much out-of-warranty
vasiljevicic - Antwort Teilen
I took mine apart to find that the jammed button was actually bent. Using two pairs of needle-nose pliers, I was able to straighten it and re-use it. The watch works great now.
keithnbrauneckermil - Antwort Teilen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 30
Insgesamt: 4,083
