Zum Hauptinhalt wechseln
Gateway MS2285 RAM Replacement
Was du brauchst
  1. Gateway MS2285 RAM Replacement, Turn Laptop Over: Schritt 1, Bild 1 von 1
    • Turn the laptop over so that the underside is facing towards you.
    Frag FixBot
    Kommentar hinzufügen
  2. Gateway MS2285 RAM Replacement, Unlock The Battery: Schritt 2, Bild 1 von 2 Gateway MS2285 RAM Replacement, Unlock The Battery: Schritt 2, Bild 2 von 2
    • Slide the short slider one towards the unlocked lock symbol.
    Frag FixBot
  3. Gateway MS2285 RAM Replacement, Release The Battery: Schritt 3, Bild 1 von 2 Gateway MS2285 RAM Replacement, Release The Battery: Schritt 3, Bild 2 von 2
    • Slide the long slider towards the unlocked lock icon.
    • This slider is spring loaded and may require a little force.
    • If done correctly, a click will be heard and the battery will be slightly raised.
    Frag FixBot
  4. Gateway MS2285 RAM Replacement, Remove The Battery: Schritt 4, Bild 1 von 2 Gateway MS2285 RAM Replacement, Remove The Battery: Schritt 4, Bild 2 von 2
    • Grasp the battery's raised end and lift upwards.
    Frag FixBot
  5. Gateway MS2285 RAM Replacement, Unscrew Backplate: Schritt 5, Bild 1 von 2 Gateway MS2285 RAM Replacement, Unscrew Backplate: Schritt 5, Bild 2 von 2
    • Use the phillips head screwdriver to remove the five screws holding the back plate.
    • The screws are counter-clockwise threaded.
    Frag FixBot
  6. Gateway MS2285 RAM Replacement, Remove Back Plate: Schritt 6, Bild 1 von 3 Gateway MS2285 RAM Replacement, Remove Back Plate: Schritt 6, Bild 2 von 3 Gateway MS2285 RAM Replacement, Remove Back Plate: Schritt 6, Bild 3 von 3
    • Place fingers under back plate via the indentation and lift upwards to remove.
    Frag FixBot
  7. Gateway MS2285 RAM Replacement, Unlock Upper RAM Module: Schritt 7, Bild 1 von 3 Gateway MS2285 RAM Replacement, Unlock Upper RAM Module: Schritt 7, Bild 2 von 3 Gateway MS2285 RAM Replacement, Unlock Upper RAM Module: Schritt 7, Bild 3 von 3
    • Push the upper RAM module's two pins outwards at the same time.
    • If done correctly, the module should have lifted.
    Frag FixBot
  8. Gateway MS2285 RAM Replacement, Remove Upper RAM Module: Schritt 8, Bild 1 von 2 Gateway MS2285 RAM Replacement, Remove Upper RAM Module: Schritt 8, Bild 2 von 2
    • Grab onto the module and pull away in a straight direction.
    • Do not touch the gold connectors.
    Frag FixBot
  9. Gateway MS2285 RAM Replacement, Unlock Lower RAM Module: Schritt 9, Bild 1 von 3 Gateway MS2285 RAM Replacement, Unlock Lower RAM Module: Schritt 9, Bild 2 von 3 Gateway MS2285 RAM Replacement, Unlock Lower RAM Module: Schritt 9, Bild 3 von 3
    • Push the lower RAM module's two pins outwards at the same time.
    Frag FixBot
  10. Gateway MS2285 RAM Replacement, Remove Lower RAM Module: Schritt 10, Bild 1 von 3 Gateway MS2285 RAM Replacement, Remove Lower RAM Module: Schritt 10, Bild 2 von 3 Gateway MS2285 RAM Replacement, Remove Lower RAM Module: Schritt 10, Bild 3 von 3
    • Like removing the upper module, grab the module and pull away in a straight direction.
    Frag FixBot
Abschluss
UMass Dartmouth, Team 1-7, Shastany Fall 2014 Mitglied von UMass Dartmouth, Team 1-7, Shastany Fall 2014
UMASSD-SHASTANY-F14S1G7
3 Mitglieder
6 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 6
Letzte 30 Tage: 34
Insgesamt: 2,910
