Zum Hauptinhalt wechseln
GoPro Hero LCD Screen Replacement
Was du brauchst
  1. GoPro Hero LCD Screen Replacement, Casing: Schritt 1, Bild 1 von 1
    • Power off your GoPro before beginning disassembly.
    • Unclip the black latch to the camera case and open the case.
    Frag FixBot
    Kommentar hinzufügen
  2. GoPro Hero LCD Screen Replacement: Schritt 2, Bild 1 von 1
    • Gently pry the back open by inserting a metal spudger between the case and back panel.
    Frag FixBot
  3. GoPro Hero LCD Screen Replacement: Schritt 3, Bild 1 von 1
    • Disconnect the battery from the motherboard by unplugging the red, white, and black wires from the white adapter.
    Frag FixBot
  4. GoPro Hero LCD Screen Replacement: Schritt 4, Bild 1 von 1
    • Disconnect the ribbon cable from the lens by lifting the black latch and gently pulling the ribbon cable from the socket.
    Frag FixBot
  5. GoPro Hero LCD Screen Replacement: Schritt 5, Bild 1 von 1
    • Use a Phillips screwdriver (PH000) to remove the four screws around the white plastic piece.
    • Make sure to keep track of these screws as they are very small.
    Frag FixBot
  6. GoPro Hero LCD Screen Replacement: Schritt 6, Bild 1 von 1
    • Carefully remove the motherboard and white plastic piece from the case.
    Frag FixBot
  7. GoPro Hero LCD Screen Replacement, LCD Screen: Schritt 7, Bild 1 von 2 GoPro Hero LCD Screen Replacement, LCD Screen: Schritt 7, Bild 2 von 2
    • Remove the larger ribbon cable from the daughter board by lifting the black latch and pulling the ribbon cable gently from the socket.
    • Disconnect the smaller ribbon cable leading from the white plastic piece by simply pulling it from the socket.
    Frag FixBot
  8. GoPro Hero LCD Screen Replacement: Schritt 8, Bild 1 von 1
    • Separate the motherboard from the white piece of plastic.
    Frag FixBot
  9. GoPro Hero LCD Screen Replacement: Schritt 9, Bild 1 von 1
    • Remove the ribbon cable from the motherboard by simply pulling the cable from the socket.
    Frag FixBot
  10. GoPro Hero LCD Screen Replacement: Schritt 10, Bild 1 von 2 GoPro Hero LCD Screen Replacement: Schritt 10, Bild 2 von 2
    • Separate the LCD screen from the motherboard.
    Frag FixBot
Abschluss
6 weitere Personen haben diese Anleitung absolviert.
Cal Poly, Team 12-2, Lancaster Spring 2015 Mitglied von Cal Poly, Team 12-2, Lancaster Spring 2015
CPSU-LANCASTER-S15S12G2
4 Mitglieder
18 Anleitungen geschrieben
3 Kommentare zur Anleitung
Where do you buy the replacement lcd
Anthony Volatile - Antwort Teilen
Gopro hero 7 white repair cost:
Screen: $45 - https://www.ebay.com.au/itm/183828969944
Side panel: $35 - https://www.herogear.com.au/genuine-repl...
Addisen KING - Antwort Teilen
I can find the screen but is it compatible with the Hero+
Brian Casado - Antwort Teilen
Seitenaufrufe:
Letzte 24 Stunden: 7
Letzte 7 Tage: 43
Letzte 30 Tage: 130
Insgesamt: 27,337
