Zum Hauptinhalt wechseln
GoPro Hero Motherboard Replacement
Was du brauchst
    1. GoPro Hero Motherboard Replacement, Casing: Schritt 1, Bild 1 von 1
      • Power off your GoPro before beginning disassembly.
      • Unclip the black latch to the camera case and open the case.
      Frag FixBot
      Kommentar hinzufügen
    2. GoPro Hero Motherboard Replacement: Schritt 2, Bild 1 von 1
      • Gently pry the back open by inserting a metal spudger between the case and back panel.
      Frag FixBot
    3. GoPro Hero Motherboard Replacement: Schritt 3, Bild 1 von 1
      • Disconnect the battery from the motherboard by unplugging the red, white, and black wires from the white adapter.
      Frag FixBot
    4. GoPro Hero Motherboard Replacement: Schritt 4, Bild 1 von 1
      • Disconnect the ribbon cable from the lens by lifting the black latch and gently pulling the ribbon cable from the socket.
      Frag FixBot
    5. GoPro Hero Motherboard Replacement: Schritt 5, Bild 1 von 1
      • Use a Phillips screwdriver (PH000) to remove the four screws around the white plastic piece.
      • Make sure to keep track of these screws as they are very small.
      Frag FixBot
    6. GoPro Hero Motherboard Replacement: Schritt 6, Bild 1 von 1
      • Carefully remove the motherboard and white plastic piece from the case.
      Frag FixBot
    1. GoPro Hero Motherboard Replacement, Motherboard: Schritt 7, Bild 1 von 2 GoPro Hero Motherboard Replacement, Motherboard: Schritt 7, Bild 2 von 2
      • Remove the larger ribbon cable from the daughter board by lifting the black latch and pulling the ribbon cable gently from the socket.
      • Disconnect the smaller ribbon cable leading from the white plastic piece by simply pulling it from the socket.
      Frag FixBot
    2. GoPro Hero Motherboard Replacement: Schritt 8, Bild 1 von 2 GoPro Hero Motherboard Replacement: Schritt 8, Bild 2 von 2
      • Separate the white plastic piece from the motherboard.
      Frag FixBot
Abschluss
4 weitere Personen haben diese Anleitung absolviert.
Cal Poly, Team 12-2, Lancaster Spring 2015 Mitglied von Cal Poly, Team 12-2, Lancaster Spring 2015
CPSU-LANCASTER-S15S12G2
4 Mitglieder
18 Anleitungen geschrieben
2 Kommentare zur Anleitung
So after doing all theses steps did it resolve the problem
Anita - Antwort Teilen
Thanks so much I really needed this guide.
Thanks, Sam
Sam Liam Matthews - Antwort Teilen
Seitenaufrufe:
Letzte 24 Stunden: 5
Letzte 7 Tage: 23
Letzte 30 Tage: 101
Insgesamt: 11,981
