Zum Hauptinhalt wechseln
GoPro Hero3+ Silver Edition Image Sensor Replacement
Was du brauchst
    1. GoPro Hero3+ Silver Edition Image Sensor Replacement, Battery: Schritt 1, Bild 1 von 2 GoPro Hero3+ Silver Edition Image Sensor Replacement, Battery: Schritt 1, Bild 2 von 2
      • Push the tab on the back of the device left to remove the plate covering the battery.
      Frag FixBot
      Kommentar hinzufügen
    2. GoPro Hero3+ Silver Edition Image Sensor Replacement: Schritt 2, Bild 1 von 1
      • Use the strip of tape on the battery to remove the battery from the housing.
      Frag FixBot
    1. GoPro Hero3+ Silver Edition Image Sensor Replacement, Front Panel: Schritt 3, Bild 1 von 1
      • Insert a plastic opening tool in between the front face plate and the black housing.
      • Make sure you insert the plastic opening tool next to the microSD card slot. There is a small gap that will help separate the face plate.
      Frag FixBot
    2. GoPro Hero3+ Silver Edition Image Sensor Replacement: Schritt 4, Bild 1 von 1
      • Continue to use the plastic opening tool and separate the front face plate from the rest of the device.
      • There is adhesive that helps attach the front face plate. Some extra prying may be required to separate the face plate, but do not use excessive force.
      Frag FixBot
    1. GoPro Hero3+ Silver Edition Image Sensor Replacement, Image Sensor: Schritt 5, Bild 1 von 3 GoPro Hero3+ Silver Edition Image Sensor Replacement, Image Sensor: Schritt 5, Bild 2 von 3 GoPro Hero3+ Silver Edition Image Sensor Replacement, Image Sensor: Schritt 5, Bild 3 von 3
      • Locate the four 8.1mm PH00 screws on the corners of the GoPro and unscrew them using the phillips screwdriver.
      • Gently remove the motherboard by using a plastic opening tool to pry it out of the housing.
      • Be careful not to damage the ribbon cable connected to the GoPro housing and motherboard.
      Frag FixBot
    2. GoPro Hero3+ Silver Edition Image Sensor Replacement: Schritt 6, Bild 1 von 2 GoPro Hero3+ Silver Edition Image Sensor Replacement: Schritt 6, Bild 2 von 2
      • Remove the ribbon cable by carefully flipping the black clip up with the plastic opening tool and pulling the cable out.
      Frag FixBot
    3. GoPro Hero3+ Silver Edition Image Sensor Replacement: Schritt 7, Bild 1 von 1
      • Remove the four 4mm PH00 screws attaching the image sensor to the motherboard with your screwdriver.
      Frag FixBot
    4. GoPro Hero3+ Silver Edition Image Sensor Replacement: Schritt 8, Bild 1 von 2 GoPro Hero3+ Silver Edition Image Sensor Replacement: Schritt 8, Bild 2 von 2
      • Pry off the last ribbon cable with a plastic opening tool.
      • Remove the image sensor from the motherboard.
      Frag FixBot
Abschluss
4 weitere Personen haben diese Anleitung absolviert.
Cal Poly, Team 5-8, Maness Fall 2015 Mitglied von Cal Poly, Team 5-8, Maness Fall 2015
CPSU-MANESS-F15S5G8
4 Mitglieder
72 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 28
Letzte 30 Tage: 93
Insgesamt: 1,308
