Einleitung
This repair guide was authored by the iFixit staff and hasn’t been endorsed by Google. Learn more about our repair guides here.
Follow this guide to correctly apply back cover adhesive to your Pixel 3 after a repair.
Before you begin, you should have already removed your Pixel’s back cover and set it aside. Detailed instructions for this can be found here.
Was du brauchst
Pick and scrape away the old adhesive from the frame.
Use a spudger to scrape away any lingering adhesive.
For best results, clean the area underneath the removed adhesive with 90% or greater isopropyl alcohol to prep the surface for the new adhesive.
Repeat the previous step for the back cover adhesive.
Peel away the clear plastic lining to expose the frame side of the replacement adhesive.
Lower the adhesive onto the frame.
Use the rear camera and corners to properly align the adhesive.
Use the flat end of a spudger or your fingernail to press down on the adhesive.
Slide along the perimeter to secure the adhesive to the frame.
Peel away the blue outer plastic lining on the back cover side of the adhesive.
In diesem Schritt verwendetes Werkzeug:Tweezers$4.99
Use tweezers or your fingers to position the fingerprint sensor cable over its connector on the motherboard.
Use the flat end of a spudger or your finger to press down on the connector to secure it to the motherboard.
Use tweezers or your fingers to place the bracket over the fingerprint sensor cable.
Use a Phillips PH00 screwdriver to install the two 4.1 mm screws securing the bracket to the frame.
Peel away the red plastic lining to expose the back cover side of the adhesive.
Lower the back cover onto the frame.
Press down on all edges of the back cover to secure it to the frame.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Pixel 3 Answers community for help.
10 weitere Personen haben diese Anleitung absolviert.
