Zum Hauptinhalt wechseln
Google Pixel 3 XL Back Cover Adhesive Installation
Was du brauchst
  1. Google Pixel 3 XL Back Cover Adhesive Installation, Remove adhesive residue from the frame: Schritt 1, Bild 1 von 3 Google Pixel 3 XL Back Cover Adhesive Installation, Remove adhesive residue from the frame: Schritt 1, Bild 2 von 3 Google Pixel 3 XL Back Cover Adhesive Installation, Remove adhesive residue from the frame: Schritt 1, Bild 3 von 3
    • Pick and scrape away the old adhesive from the frame.
    • Use a spudger to scrape away any lingering adhesive.
    • Don't use metal tools to scrape away adhesive as this will damage the frame.
    • For best results, clean the area underneath the removed adhesive with 90% or greater isopropyl alcohol to prep the surface for the new adhesive.
  2. Google Pixel 3 XL Back Cover Adhesive Installation, Remove adhesive residue from the back cover: Schritt 2, Bild 1 von 3 Google Pixel 3 XL Back Cover Adhesive Installation, Remove adhesive residue from the back cover: Schritt 2, Bild 2 von 3 Google Pixel 3 XL Back Cover Adhesive Installation, Remove adhesive residue from the back cover: Schritt 2, Bild 3 von 3
    • Repeat the previous step for the back cover adhesive.
    • Don't use metal tools to scrape away adhesive as this will damage the back cover coating.
    • Don't use isopropyl alcohol near the rear camera bracket as it will damage its adhesive and foam.
  3. Google Pixel 3 XL Back Cover Adhesive Installation, Prepare the replacement adhesive: Schritt 3, Bild 1 von 1
    • Peel away the plastic lining to expose the frame side of the replacement adhesive.
  4. Google Pixel 3 XL Back Cover Adhesive Installation, Apply the adhesive: Schritt 4, Bild 1 von 3 Google Pixel 3 XL Back Cover Adhesive Installation, Apply the adhesive: Schritt 4, Bild 2 von 3 Google Pixel 3 XL Back Cover Adhesive Installation, Apply the adhesive: Schritt 4, Bild 3 von 3
    • Be very careful during this step! The adhesive is very sticky and can't be repositioned once it sticks. Misaligned adhesive can lead to an improper seal.
    • Lower the adhesive onto the frame.
    • Use the holes in the frame to properly align the adhesive.
  5. Google Pixel 3 XL Back Cover Adhesive Installation, Secure the adhesive to the frame: Schritt 5, Bild 1 von 3 Google Pixel 3 XL Back Cover Adhesive Installation, Secure the adhesive to the frame: Schritt 5, Bild 2 von 3 Google Pixel 3 XL Back Cover Adhesive Installation, Secure the adhesive to the frame: Schritt 5, Bild 3 von 3
    • Use the flat end of a spudger or your fingernail to press down on the adhesive.
    • Slide along the perimeter to secure the adhesive to the frame.
  6. Google Pixel 3 XL Back Cover Adhesive Installation, Connect the fingerprint sensor: Schritt 6, Bild 1 von 3 Google Pixel 3 XL Back Cover Adhesive Installation, Connect the fingerprint sensor: Schritt 6, Bild 2 von 3 Google Pixel 3 XL Back Cover Adhesive Installation, Connect the fingerprint sensor: Schritt 6, Bild 3 von 3
    In diesem Schritt verwendetes Werkzeug:
    Kaufen
    • Use tweezers to guide the fingerprint sensor cable into its socket.
    • Press down on the latch to secure it.
  7. Google Pixel 3 XL Back Cover Adhesive Installation, Peel away the remaining plastic lining: Schritt 7, Bild 1 von 2 Google Pixel 3 XL Back Cover Adhesive Installation, Peel away the remaining plastic lining: Schritt 7, Bild 2 von 2
    • Peel away the plastic lining to expose the back cover side of the adhesive.
  8. Google Pixel 3 XL Back Cover Adhesive Installation, Secure the back cover to the frame: Schritt 8, Bild 1 von 2 Google Pixel 3 XL Back Cover Adhesive Installation, Secure the back cover to the frame: Schritt 8, Bild 2 von 2
    • Lower the back cover onto the frame.
    • Press down on all edges of the back cover to secure it to the frame.
    • To help the adhesive bond more securely, heat the perimeter of the back cover and then place the phone face-down under a heavy stack of books for 30 minutes.
Abschluss
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Pixel 3 XL Answers community for help.
5 weitere Personen haben diese Anleitung absolviert.
Chayton Ritter
19.544 Reputation
105 Anleitungen geschrieben
Guide Team Mitglied von Guide Team
Staff
8 Mitglieder
8.212 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 28
Letzte 30 Tage: 70
Insgesamt: 1,517
