Zum Hauptinhalt wechseln
HMDX Jam Battery Replacement
Was du brauchst
    1. HMDX Jam Battery Replacement, Opening speaker: Schritt 1, Bild 1 von 1
      • Use the plastic opening tool to pry off the rubber cover at the bottom of the speaker.
      Frag FixBot
      Kommentar hinzufügen
    2. HMDX Jam Battery Replacement, remove rubber cover: Schritt 2, Bild 1 von 1
      • Gently remove the rubber cover to expose the screws. If necessary, poke holes through the glue residue to expose the screw heads.
      Frag FixBot
    3. HMDX Jam Battery Replacement, Remove screws: Schritt 3, Bild 1 von 1
      • Once you have exposed the screws, use a #1 Phillips screwdriver to remove the four 9 mm screws.
      • It would be wise to use a magnetic mat for the screws for safekeeping.
      Frag FixBot
    4. HMDX Jam Battery Replacement, Exposing Battery: Schritt 4, Bild 1 von 1
      • Once you've removed the screws, open the case slowly. The battery is covered in blue packaging.
      Frag FixBot
    5. HMDX Jam Battery Replacement, Removing Battery: Schritt 5, Bild 1 von 1
      • Very gently remove the battery from the motherboard.
      Frag FixBot
    6. HMDX Jam Battery Replacement, Remove battery attachments: Schritt 6, Bild 1 von 2 HMDX Jam Battery Replacement, Remove battery attachments: Schritt 6, Bild 2 von 2
      • Use a solder gun to remove the battery attachments from the motherboard.
      Frag FixBot
Abschluss
42 weitere Personen haben diese Anleitung absolviert.
USF Tampa, Team 1-1, Blackwell Winter 2015 Mitglied von USF Tampa, Team 1-1, Blackwell Winter 2015
USFT-BLACKWELL-W15S1G1
4 Mitglieder
14 Anleitungen geschrieben
18 Kommentare zur Anleitung
Looks like a great solution to fixing the speaker with a battery with a short life span. But what's the amperage of the lithium barberry and where can I purchase one ?
Stephen Lavizzo - Antwort Teilen
Did you ever find out where to purchase a new battery for it?
DJ Ethics - Antwort Teilen
Hey Stephen. Can you tell me where i can buy a replacement battery for my P120
Lynchfield Daniel - Antwort Teilen
On my Model: HX-P240A
KANYO 383541P 3.7V
520mAh 1.924Wh
534114364A17142
minhngoctruong - Antwort Teilen
My Bluetooth speaker just has a rubber suction on the bottom. There is no area to replace a battery. Is there any way to reset I?
bdale46 - Antwort Teilen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 23
Letzte 30 Tage: 110
Insgesamt: 98,797
