Zum Hauptinhalt wechseln
HP 15-R263DX Keyboard Replacement
Was du brauchst
  1. HP 15-R263DX Keyboard Replacement, Battery: Schritt 1, Bild 1 von 2 HP 15-R263DX Keyboard Replacement, Battery: Schritt 1, Bild 2 von 2
    • Eject the battery from the computer by sliding the two clips on the bottom of the computer toward the center of the computer.
    • Slide the battery out as shown in the picture.
    Frag FixBot
    Kommentar hinzufügen
  2. HP 15-R263DX Keyboard Replacement, Keyboard: Schritt 2, Bild 1 von 1
    • Once keyboard is loose, do not immediately remove it from the computer. It is attached by a ribbon connector.
    • Using a metal wedge tool, pry up along the top edge of the keyboard until all clips are disengaged and the keyboard is loose from the computer.
    Frag FixBot
  3. HP 15-R263DX Keyboard Replacement: Schritt 3, Bild 1 von 1
    • To disconnect the ribbon connector, flip up the black clip shown in the picture.
    • Gently pull the ribbon until disconnected.
    Frag FixBot
Abschluss
Washington State, Team S2-G3, Lobnitz Spring 2018 Mitglied von Washington State, Team S2-G3, Lobnitz Spring 2018
WSU-LOBNITZ-S18S2G3
8 Mitglieder
7 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 14
Insgesamt: 677
